Okay - yep there are 30+ pages of notes and misc comments and observations but even I dont have time to read through them all to find what I want so here ya go...
You don't give us the AH or C of your headaway packs but only that they are the 36v and 72v nominal packs... Could you specify how many cells each is in series?
According to a post by YPedal he has been charging at fast rate to 3.7v per cell and then letting them go as far as 3.9v per cell before charge termination... I think this is correct with Headaways... so
[36v Nominal Headaway LiFePo4]
Nominal Voltage: 3.2v
Maximum Voltage: 3.7v per cell
Pack AH: Assuming 20AH?
Assuming these are 12S packs the nominal voltage is 38.4 with a charge maximum of 44.4v - this means you want a Meanwell S-350-48 which you will modify either according to the bullet mods I will provide below or the FULL Thread elsewhere.
Configured Voltage: 44.4 Volts
Charging Current: 7.88 Amps
Now you should perform the SVR1, Thermistor and either R33 or Shunt mod to limit the current... Personally I push my S-350's to 450w output power for 7.3A @ 62.4 which works fine but the closer to 350-380 you get the more reliable.
[72v Nominal Headaway LiFePo4]
This is a 22 or a 24S pack?
I will assume 24S..
Charging Voltage: 88.8v (3.7v per cell, 3.6 is safer for 86.4)
This may be possible with a single S-350-48 though I have never tried to go beyond 63v, the caps are 100v... it will require a bit more current limiting which is a R33 mod or remove all but one shunt.
[Meanwell to Charger Mods]
#1a - Better Adjustment Resolution - Replace variable resistor SVR1 with 10 turn 1K
#1b - Raise Voltage Range (ex 15S) - To raise the voltage range, R25 should be decreased... on our example from 1.95K measured to 1.65k gets me into 15S (63v) charge range. You will also need to either add diodes in series with ZD1 to raise it's 62v limit or replace with proper value if going beyond 62v range extension
#2 - Fan Always On - Replace thermistor nearest output coil with 470-700 ohm resistor, use higher values for higher configured voltages. The fan spins faster at higher voltages so use more resistor to calibrate its output to what you want.
#3 - Remove X shunts or lower R33 to reduce charging current to within 400w @ Max Voltage (charge calibrated voltage).
#4 - Get ARCTIC SILVER thermal paste from either Radio Shack, a Computer Store, etc... be sure to coat the FETs and Flyback Diode before putting the case back together, this will ensure proper heat dissipation - without this, the fan mod is useless.
So those are the bullet points which atleast give you some keywords for searching out the full details of each mod if you need it!
Hope it helps!
-Mike
