Alexanderfoti
- Joined
- Jun 18, 2016
- Messages
- 78
Hi all
Had a search around, but couldn't find anything
Would it be possible to modify the max voltage of either the RSP-750-48 or the RSP-1000-48 just a couple of volts higher than their spec lists?
I think it should be easy enough to modify the resistance of the voltage pot (With inline resistor change) but I cant find any information or to see if anybody else has done in in the past?
This way, I Can pair them with my Eltek flatpacks to get 7.3kw charging at compatible type 2 stations.
Thanks in advance!
Thanks in advance!
