ok i'll have a bit of a play with it as time permits, I realise that back emf is linked directly to rpm ( volt/rpm) but I think there is more to it than that, as many of us are aware that damaging mosfets is often linked to a bad connection on the motor phase wires, and that spark ( assuming back emf related) is dependent on load also, eg spin the motor at no load can disconnect the phase wires no problemo, do it while motor is under load and theres a good risk of blowing the fets.
So really I'm looking at determining worst case back emf values ( which i'm guessing are going to be also load dependent not just rpm dependent)
