Lurkin
Putting together a bit of a beater bike, was thinking of trying out mechanical brakes seeing as others on here think they are the bees knees and they seem pretty simple to service without the requirement of bleeding.
Just trying to work out a cost effective option to get decent braking power, Google revealed that BB7 is the preferred option, ahead of BB5 due to the brake adjustment knob.
BB7s can be obtained here:
http://www.ebay.com.au/itm/AVID-BB7-Mountain-Fahrrad-Scheibenbremse-Mechanical-160mm-HS1-Scheiben-SD7-Hebel-/371519795152?hash=item56804e2fd0:g
zEAAOSwv-NWVWDl
BB5s can be obtained here:
http://www.ebay.com.au/itm/BB5-Mountain-Mechanical-2x-Disc-2x-Brake-Calipers-Set-Kit-HS1-rotors-160mm-White-/161398588671?hash=item25941b04ff:g:2foAAOSwxH1T8sV8
Both are with tiny discs, but they are probably sufficient for what I am using them. The BB5s is probably the better kit for money given it includes cables and is cheaper anyway. However it is from Hong Kong and is probably counterfeit.
for.
Is there any other mechanical disc brakes I should be considering?
Is there any other mechanical disc matters I should be thinking about?
for.
