I have a fat bike with a motor in the rear wheel (Bafang 250W). During a routine check of the control unit (voltage 36V, max. current 17A, rated current 8A), I discovered that all the cables connecting the battery (Li-ion Silverfish 36V/21Ah) to the control unit have partially melted insulation (shrink tubing) exactly at the connection point (where the battery cables connect to the unit cables) – see the attached photo.
The control unit is relatively new, installed approximately 15 months ago. The battery is older, installed around 5 years ago. The previous control unit (identical to the current one with the same parameters) was installed with the current battery for about 3.5 years, and the cables never showed any issues; there was no melting of the cables at all.
Does anyone know what caused the current cable melting and how to prevent it?
