larsb
I'm building a small dyno that can test most motors here, first revision max power is 30kW. It will be scaleable so it can probably go up to the double power with changed sensors and bigger flywheels. Or smaller with just other sensors.
I have based the frame on alu profiles in 90x90mm. It is an expensive choice but it allows for simple reconfiguration and scaling of the dyno just by changing/adding profiles.
The first revision is a flywheel dyno. It is the simplest form and easily gives repeatable results. Downside is that steady state testing cannot be performed, it will be best for full load optimisation - (hotrodding
). I think it can be used to optimise phase angle seeting for hall sensors, finding saturation current of motors and optimal gearing etc.
It will be possible without excessive altering to add a load cell and brake if someone wants to expand it into a brake dyno.
I'll put up all needed stuff and info here so it'll be really easy to do a version of it. It's a slow build as always for me so it'll be ready in something like a year
Edit: or more like 5 years
WIP estimates
Estimated total cost for me: about 2000 USD
Total cost for the diy guy with time&tools: 1000 USD
Weight: 120kg
Dimensions: 58x58x40 cm
Flywheel diameter: 54 cm
Flywheel material: S355J steel, 15mm thick
Flywheel weight: 26kg / each
WIP estimates
Weight: 120kg
