Hello there,
I'm going to be electrifying my dad's slick Miyata 1000 touring bike. I have a choice of motors; Either a Crystalyte 408 or an eZee for a 26". The advantage of the Crystalyte is that it has a 7 gear cluster and is intended for the rear of the bike, where the frame is definitely capable of handling the weight. The advantage of the eZee is that it performs better, producing an estimated 12 more pounds of thrust in the 26" or 700cm wheel than the Crystalyte while reaching the same top speed.
I would really rather use the eZee motor, however I am concerned about the front fork breaking with the extra weight of the motor. the eZee motor is just 3.6 Kg / 8 lbs, lighter than the Crystalyte.
Torque is always a good thing in my books, but particularly in this case as there will likely be times my dad can't pedal due to his aging body.
My actual experience with Crystalyte is null - I have tried the eZee motors on their full bikes, and they haul ass! But it's this simulator from Renaissance that showed me the differences in torque between the eZee and Crystalyte motors: http://ebike.ca/simulator/
Any thoughts are welcomed.
