marka-ee
⚡ Regular
- Joined
- Mar 24, 2020
- Messages
- 257
My Nazca Pioneer recumbent bike currently has a 1000 watt gearless hub motor. While I do like the silence of it, and since I don't have any hills near me, it works fine except for one thing:The unsprung weight is a problem for my smoothness of ride if I'm not mistaken. I am toying with the idea of a fairly unorthodox drive that would use one of the fairly common 3000 watt BLDC motors from Amazon which sell for about $250 with a controller. The drive would be a belt drive and instead of doing reductions I would basically have the belt arranged on a extremely large sprocket arrangement that would be actually attached to the 26 inch rim thereby reducing the need for any multiple level drive reduction. The drive sprocket on the motor would be roughly two inches, which would still result in a fairly silent motor setup, I believe. Does anybody have any experience with these 3000 watt motors that are sold on Amazon? The price seems a little too cheap, and I don't know if they really live up to their specifications. Cooling might be another concern, as I expect the motor will be dissipating about 350 watts inside because of the 87% efficiency that motors are supposed to have. Anyhow, this would then make my rear wheel be almost as light as if it had no special motor at all, and perhaps get me more efficiency because the motor would be spinning a lot faster and I think would be able to transfer more power this way. Let me know if you guys think that it's a little bit too kooky to try this. I don't know if anybody's ever attempted a custom rim configuration that has a sprocket essentially attached to the side of it. So basically the sprocket would be roughly 25 inches in diameter.
