More battery ideas, post up the best deals.
Lowell
Vancouver
http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=532
64.6 cents per Wh, 10c
http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=1334
57.9 cents per Wh. The sales guy said these are 3c rated.
http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=530
63.5 cents per Wh, 10c
http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=470
62.1 cents per Wh, 10c
http://www.all-battery.com/index.asp?PageAction=VIEWCATS&Category=266
71.1 cents per Wh, 1.5c li-ion. Since any worthwhile pack is going to be 100+ cells, this would drop the price down to 56.4 cents per Wh. Assuming 35 amps, 11 cells in parallel is a minimum. 20s11p pack would weigh 22.3lbs plus solder, wires/plugs and shrink wrap. 1800 Wh at close to 80 Wh per pound.
http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=1325
47.9 cents per Wh, 3c NiMH. A 60s2p pack would only cost 44.6 cents per Wh, and weigh 43.2+lbs for 1440 Wh. This seems like the best deal in larger capacity NiMH cells.
