xyster
safe said:xyster said:I find your argument rather academic, Safe, because better lithium cells are no more expensive.
The Li-ion are cheap, but then you have to do the whole BMS thing. Also, the Li-ions only make sense if you are willing to buy $500 or more. (the 1C rating requires a big initial investment) For someone who just wants a pack for $200 that can pull 36V 30 amps for 600 cycles the high discharge 10C cells are more economical. LiFePO is still expensive.
Try to build a Li-ion pack for 36V 30 amps and you need a lot of Li-ion cells.
Xyster... try running your "cheapest price scenerio" for a Li-ion 36V 30 amp pack... include all the chargers, BMS, etc...
The whole point is being cheap, cheap, cheap...
The 36v 30amp li-ion pack can be built with 100 cells (10s10p), cheap single cell chargers, and no BMS for about $500. NiMH, as you know because you were involved in the threads too, requires cell-matching as they roll off the assembly line with a high degree of variability, and each cell has a much higher failure rate. Ebikes.ca is exiting the NiMH pack business for this reason, yPedal and others here have had significant problems with NiMH cells dying and requiring replacement. Lithium does not require a BMS. NiMH does require separation of the strings for parallel charging. As widely noted at rcgroups.com, a single string of NiMH sub-C's pushed to 30 amps will live a very short life -- more like 60 cycles, not 600 cycles. So amortized over its service life, your $200 30 amp NiMH will be far more expensive to maintain than a $500 lithium pack.
