electron bom
I searched the forums and have found scant mention, much less personal report on the nuances of this Brushed PM motor. If anyone has personal experience with this motor please share. I'm nearing the end of my build and I'm not quite sure what to expect. On paper it should perform well. The motor is going in an off-road buggy that has been repurposed for tarmac.
The original ICE made 9hp/13ftlbs somewhere around 7500 and 5500rpms respectively. It utilized a CVT which I never opened so I'm ignorant to the actual gearing. Curb weight was right at 500lbs. Top speed was ~35ish mph and acceleration was pitiful, so out went the original setup.
To start, I will be using LiFePO4 CALB 100AH cells in 16s configuration. Assuming ~90% efficiency and assuming I can pull 200A constant with out issue, I should be good for 9.2Kw or 12.4hp. At nominal voltage of 51.2V the ME1003 will be doing 2200rpms, if my Kw figure is correct then that means the motor will be producing 29.6ftlbs. My current gearing is 2:1 so I'm expecting 25whp and 60wtq. The kart's current configuration tips the scales right at 530lbs so on paper this all looks nice, but I'm assuming that the ME 1003 will be happy pulling 200A continuous at 48V. Anyone with e-kart or ME1003 experience please chime in! Here are some pics.
