minde28383
- Joined
- Apr 2, 2010
- Messages
- 702
How many miles or kilometres you covered before you had to or decided to replace motor bearings.
Describe as many as possible but at least first four things:
1. How many miles or kilometres you travelled before bearings had to be replaced or you decided to replace them
2. Reason you decided to replace bearings
3. Motor (mxus (28,30,45), qs 205 (35,45,50), bafang 500w,750w,1000w etc)
4. How/when you noticed that/if bearing(s) are broken / needs replacement
5. Describe riding style (commute, off-road, speed)
6. Describe area you were riding (hot, wet, dry, humidity, cold, or be specific - country&city)
7. Brand of the bearing you replaced
8. Time span of ebike/bearings exploitation
9. Ebike / raider weight
%. add what you think is necessary
