Motor cable exit potting ?
qwerkus
I'll probably have to swap cables on the new g0hs motor and could use some help.
1. The existing cable is very well potted. How can I best pull it out ?
2. What potting material is recommended to seal the motor cable exit ? I have rtv silicone laying around and epoxy. First one seems too weak and second one way to strong, especially if I have to change the cable again.
EDIT:
First Problem is no even the potting, but the hall pcb: how do you gurus remove it without braking the sensors ?
