dam you circuit, you are right about the phase current ripple at no load.
i just ran up a ca120 on an 80v pack and the losses at 1000-2000rpm are massive, it uses around 500w instead of around 100w that it used to, and the change is because of the high battery voltage, something changes pretty drastically
i allways thought (and allways found in practice to, till this ) that you can say double the battery volts and and with fixed phase amps that nothing really changes, and you get the same watts nearly the same efficiency (at a low fixed speed) it just uses half the amps and double the volts at the battery and the controller chops it all up with pwm to give the same end result either way, a bit more loss compared to say running very low voltage and 100% duty, as there a few tens of watts lost to fet switching etc but same enough in watts regardless of battery voltage -phase currents being equal.
so at 45-55v that i have mostly run on it was barely an issue and could hide away unnoticed, but at 80v i cant even get a 1000rpm no load idle without a 100degc motor, its ridiculous
-although it precisely matches what circuit had been banging on about, so yes a round of 'i told you so' is clearly in order. :|
