deronmoped
- Joined
- Oct 6, 2008
- Messages
- 706
Anyone know how a liquid cooled motor works?
Thanks, Deron.
Thanks, Deron.
Jozzer said:To answer the question, a watercooled motor works by circulating water around the hot bits, then pumping it into a radiator where large amounts of air can be passed over it. It can increase the amount of air you can use to cool the motor, and the liquid around the motor also helps increase the thermal mass (or better, makes a "changeable" thermal mass that constantly gets refreshed with cooler material)![]()
The problem usually is that it is usually only practical on a motor that has a static armature..
Steve
safe said:I guess the best least complicated way of getting heat out of the motor is still fan cooling. The only problem with fan cooling is keeping the dirt and water out on a bike setup.
liveforphysics said:Yeah, a typical 9mm handgun bullet goes 1150fps for a 115gr bullet. That's 7086joules. At 44v, you would only need to pull 100amps for 1.61seconds to equal the amount of energy in a 9mm bullet. I think they were getting well over 100amps for a few minutes straight, which would be many hundreds of times the energy in a bullet. Maybe they need to think of something other than bulletproof to call them![]()
