I have something to add to the post many may not have experience with.
Amped Bikes has a geared motor (rear only at the moment) that is almost totally silent, and even at WOT is not going to be louder than the sounds of a normal bike going down the road.
Compared to my father's DD Amped Kit (still not 100% sure if it's one of the 9c motors or later design) my geared motor makes no more sound than his DD for 75% of the throttle, it's only at 80%+ that it makes a bit of a "turbo jet" whine thats really kewl, I will do a video later so those of you who have other brands of geared motors can tell me how loud or quiet mine is by comparison. 8)
I also wanted to add on the rear freewheel gears, I started with a 9 cog cassette with a 11 tooth top gear. If you think about it, even when your riding your bike un-powered, do you
really use all those gears? I have found that sticking with the best cadence (for me 65 - 70 RPM's at the crank) 90% of the time, I use maybe 3 -4 gearing combinations. I go up hills a lot where I live, so often I'm either in my lowest gear or close to it going up something steep, my highest gear going down, or some form of the med-high gearing on the flats.
Now that I have added my Amped Bikes rear geared motor, I am almost always in the med-high to high gear range. Going down-hill I had to do some changing however, since I can only get a 12 tooth for my tallest gear in the rear freewheel by going larger on the front.
Currently, I have something that looks more like a road-bike's gears +1 tiny gear for hills if I ever had to slug it up a hill with a dead battery. I have a 52, 48 (the 48 was my old high gear! :lol: ) and 28 up front. The rear freewheel is a custom combination 7 speed with 32 for the low and a 12 for the high.
ElectricEd said:
I pretty much agree with all of the above.
Forget about taking a 408 without battery on the trails with your mates. The drag from motor cogging feels like running one of those tyre rubbing dynamos of yesteryear. On a technical hilly trail you'll be stuffed in no time. Adding to that, if you don't get a 408 with the latest mod with a moulded in steel insert for the threaded cluster boss, in granny gear you're likely to rip it out of the side plate. This has happened to me and others from this forum.
http://endless-sphere.com/forums/viewtopic.php?f=3&t=9205&p=142756#p142756
+1 on the resistance felt with most DD's I can only speak to an early model of Amped Bikes DD motor (most likely the ones 9c started selling to all buyers w/o Amped Bike's permission
) but I can remember especially when we had this kit and a SLA battery that unless I was riding under power all the extra weight(34lbs of battery!
) + the resistance of the DD motor's magnets, it was like riding a bike on moist beach sand, not dry enough to keep you from moving, but close! Even once we got some nice light Dewalts on dad's bike, I could still notice that considerable resistance from the motor. That is one of the main reasons I got my kit as a geared motor, only 9lbs (less than half the weight of the 20lb early DD!
) and the 100% freewheeling.
I agree on principle that you wouldn't really ever run ANY E-Bike with-out the batteries to save weight and go nutz on the trails trying to use it as a regular bike, but it can be done. My build at 59lbs total for bike + batteries & motor kit is light enough for me to pedal up the steep hills I have climbed in the past with out really noticing the weight, however that isn't really to compare to flogging your MTB on a technical trail! :lol:
ElectricEd said:
The cheap rims that come with most electric motors can't cope with any sort of rough treatment like kerbs or small jumps, so barrelling down a bumpy trail at top speed is a definite no-no.
I'd recommend a geared motor if you really want to use the same bike. They a smaller, lighter and have no cogging drag because of the free-wheel built into the gearing mechanism. Chuck away the rim and rebuild the wheel with a quality semi deep-V rim and SS spokes. There is nothing worse than that long walk home caused by equipment failure. Murphy's law ensures that this will happen at the most distant point from home. :wink:
I can't agree more! One of the reasons Danny started his company was because he couldn't seem to find a decently built wheel with most E-Bike kits on the market, to his credit I can say that my father's bike with first a trailer holding 3 SLA CAR BATTERIES!?!?!
:lol: in a trailer totaling no less than 110lbs (we were REALLY n00bs then
:lol: ) and then later with one car battery and 2 SLA scooter batteries (34lb battery pack) on the back rack, we were not diligent about checking the spokes regularly.
Even though we did everything wrong, and only tightened the spokes after realizing that the "high speed wobble" down our favorite/most hated (depended on if you are going down or up hehe :wink: ) was really the spokes that were finger loose!!
Fortunately for us, no mis-haps and all we ended up having to do was tighten up the spokes and go on home.
Which ever kit you get, be SURE to check that the wheels are properly dished, spokes are tight, and I would strongly advise 12G SS spokes if your kit doesn't come with them. I had to buy a new spoke wrench for the 12G spokes that my geared kit came with, but I'm sure that in the end I will be glad to have them. Also, you want to make sure your kit has a good double wall rim. I prefer over-engineered to under-engineered, usually costs less in the end. :wink:
Just my $.02
