_alice_
I have foldable 20" ebike that has turned on it's motor randomly while I have been waiting for example green light. Last and final time caused my other arm to be unusable for few weeks, so I'm wanting to replace all risky electronics as otherwise the bike is decent.
With first incidents I thought I had accidentally somehow touched switch for walking assist (with it bike should go max to 6km/h) but I physically prevented that switch from moving afterwards - didn't fix the issue. I also think that the motor put much more power on than what it does when the assist goes on.
Last time the motor stopped only after I pressed brakes which luckily had been fixed just before as bike also had had the issue that pressing brake was not stopping the motor. On the same occasion motor turned back on when I released the brakes (I think maybe not immediately but not sure as I had crashed to ground pretty badly, so not too well in my senses back then).
Information of the bike:
* 36V
* Motor: Ningbo siwei motor JKXH36V250W20 1712110063
* Controller: KZQW22A-LKTS17066-8120, Suzhou Tongsheng bicycle Co. Ltd
* has one USB port up to 2.1A
What parts and sensors you think I should change? Or should it all be trashed? And being really noob with these: what would be the correct parts to buy?
Also, I would like to add rear light to it because it becomes now mandatory here by law. Do you think it would be possible to just add some light to the cable that goes to front light? Or is there risk to put too much load to the wire then?
PS: I did contact place where I got the bike and did get my money back on it AND to keep the bike. Now just I would prefer to fix it instead of trashing it as that would seem like waste of good parts.
* 36V
