theprodigyp
- Joined
- Sep 18, 2013
- Messages
- 48
Okay, well I have been pretty busy with work/school and have not done much with my current build but there was a problem that maybe others are having that I have thought of. I know the ABS MBS mountain board trucks do not have any sort of suspension and I was wondering if the upgraded ones made a difference in smoothness with motors? After Everything I have went through and the fact that I have broken 2 motors on 2 separate occasions I am looking to solve this issue. One thing I was thinking is because one of my motors broke because of a difference in the road so a small bump/speed bump broke the shaft when I was going about 15 mph over it. I dont know if anyone has ever had a problem like this and how they solved it? I will just go slower next time but I was also thinking that you could suspend the motors to help compensate for such events? I was thinking along the lines of some type of mount that had springs in it so that when you would go over a bump that the motor could have some room to compensate for the change. I have some sort of idea I just dont know if it would be possible. I think maybe only on a vertical axis it could work but if you did both vertical and horizontal that there wouldnt be a simple design. Does anyone else have some ideas?
