oatnet
Nice workshop - I envy the space!
-JD
-JD
johnhead@frontiernet.net said:Mark, Will you be offering the caliper and rotor in the future as a complete "Braking" package "option"?
I won't need it as I did get in new rotors for my two motors. I may be doing a slight redesign on the anchoring of my two however. Innovation can be fun and hopefully rewarding?
Regards
John
tritonwow said:Tell me that's my wheel...
Lee in Japan
markcycle said:Some time ago I showed the caliper integrated into the torque arm Then I backed away from the idea
Now I happy to show the concept implemented
Mark
TomA said:markcycle said:Some time ago I showed the caliper integrated into the torque arm Then I backed away from the idea
Mark
Hi Mark:
This is great. Can you tell me what this unit weighs as it sits, with the arm, caliper and disc mounted?
Thanks,
TomA
todayican2 said:That share may be worth a bit more now...
http://www.treehugger.com/files/2009...unding-doe.php
Looks like congress likes electric trikes now too :-D
For a full size motorcycle trike I am working on a center mounted twin hub motor design. You would retain the standard wheels of the trike and use the hub motors as a differential mounted inboard as a car's differential is mounted, with shafts to the wheels.
Drawings aren't ready yet for show should have something to sell in about 3 to 6 weeks.
Are you getting any closer to some specs and drawings?![]()
Might be nice to put that in a Suzuki Swift or Honda Civic.![]()
Thanks,
Eric
Malcolm said:Interesting comparison. The energy density makes a convincing argument for Lipo, but one thing that caught me eye was your price for Thundersky cells – you can get the 60Ah cells for 2.72 Wh/$ at evcomponents. Edit: to be fair, the Thundersky cells don't really compare on performance either as they're only good for about 5C max. A better comparison might be with the new Headway cells that evcomponents say they'll be offering soon.
oatnet said:Running at 10c continious, even to 100% dod, would give you a 6 minute run time. Would your build be for exhibition or commuting?
-JD
Persanity said:I know this has probaly been asked but, What is the torque on the 602 motor at the voltages and amps on the EnerTrac website? ie 72v 50 amps & 96v 95 amps?
