nonlineartom
I've put 1,500 miles on my commuter bike since March, it was a £50 rubbish deathtrap to start with so I've retired it to be replaced with a Saracen Raw 2 mountainbike, I got it because it was very cheap, hydraulic brakes, deeeeeeep dropouts and a nice big flat mounting surface to epoxy on some torque arms. I am however now faced with the dilema of how to securely mount 7KG of LifePo4 battery that will handle harsh potholes and big speed bumps. The old bike was a hardtail so a £20 pannier rack was all I needed, it clattered around a bit but with 3 elastic luggage straps it was never at any risk of going anywhere. Here is the bike in question
This was from when I took it for a nice test ride over the moors with the battery pack in a rucksack, this isn't practical for commuting as I need to carry a rucksack full of work stuffs. I've used a Topeak beamrack before as the battery lives inside a Topeak DX pannier bag with the quick track system, it just fits in and keeps the weather off it. I've used a Topeak beam rack before rated for 9KG and after a month the QR bolt snapped as I predicted. I've bought a cheap seatpost pannier that mounts with 4 bolts but the topeak bag doesn't sit very well on it at all and wobbles around, there is also a clearance issue because there is 5" of travel in the rear suspension a big bump means the tire scrapes on the beam, has anyone else had this problem and found a solution? Open to ideas.
