You could mount it on there the same way wheelchair handrails are done to their wheels, by using spacers on the bolts that secure it, to hold it out away from the wheel for the chain.
I recommend that you put the bolts as far outward in the wheel as you can, so there is less torque on them and their moutning points on the wheel.
I also recommend you bolt a spacer on the hub-hole of the sprocket so that it fits as tightly as possible around the hub of the wheel. Will help give more support to the assembly.
