Sinbord1981
- Joined
- Apr 12, 2019
- Messages
- 131
:thumb:
Sinbord1981 said:Yep. Order placed today. They’re waiting on a new batch of the Rockshox Lyric forks to come in but should be with me by end MayRazerr said:Any update you got for us? Did you order?
Where and how much?BigBoris said:Hello, I ordered a Top of the line Frey 1000 watt duel suspension bike. My original reason for buying it was to commute to work. When it came I realized that it was too big of a bike for my to keep in my office. I would like to sell it, please email me if you are interested. It has 20 miles on it.
Bafang Ultra 48V 1000W mid drive system with throttle;
48V 21AH Samsung 35E cells powered big capacity battery;
ROCKSHOX YARI 160mm air suspension fork;
ROCKSHOX DELUXE RL rear suspension;
MAGURA MT5e 4-piston hydraulic brake with power cut function for ebike use;
SHIMANO XT M8000 11 speed group set;
MAXXIS 27.5*2.8" mountain tire.
1 extra battery
Hardcore said:48v battery is about 10% more Wh and about 8% less max. power. But in my experience, the 52v will give you less voltage drop under high load and more consistent power 'feel' throughout the full use of the pack.
Where do you live, whats frame size and how much do you ask?BigBoris said:Hello, I ordered a Top of the line Frey 1000 watt duel suspension bike. My original reason for buying it was to commute to work. When it came I realized that it was too big of a bike for my to keep in my office. I would like to sell it, please email me if you are interested. It has 20 miles on it.
Razerr said:Are there battery readout problems on the Bafang screen, can it handle 52v? Less voltage drop sound like a more pleasant ride.
I going to buy 2 batteries so 10% less Wh isn't a problem.
Hardcore said:Razerr said:Are there battery readout problems on the Bafang screen, can it handle 52v? Less voltage drop sound like a more pleasant ride.
no problems reading the voltage on the screen and yes it is a pleasant ride. I have another 48v hub and I can certainly feel the battery reaching LVC while the 52v on the frey keeps more power till LVC
cheers
Yes i do, pretty close to make the order.Sinbord1981 said:Razerr said:Thanks for the info, I am sold for 52v
I was having the same dilemma but opted for two of the 48V21ah batteries with my AM1000. Surely you’ll have less potential peak power with them but a longer burn given the fact that they’ve got 14% more capacity in the first place (48x21=1,008 WHr vs 52x17=884). Whilst the voltage on the 52 is obviously higher than the 48 it will drop faster at the same drain level.
....or have I got this all wrong and I should also change for the 52V17ah.
Are you about to order an AM1000 Razerr?
Razerr said:Now the frame size. I am 5.9 feet (+-181cm) I was thinking of the large variant.
I would like some opinions of the frey bike owners.
Sinbord1981 said:I’ve already placed my order with Frey and paid for the AM1000 with two 48V21ah batteries but I have asked whether I can switch to two 52V17ah batteries instead, obviously with the correct charger for the 52V pack. I’ll let you know how I get on. It is a difficult one and I guess six of one and half a dozen of the other in terms of weighing it up. Thanks.
SunnyDay1 said:Razerr said:Now the frame size. I am 5.9 feet (+-181cm) I was thinking of the large variant.
Go with the medium frame size if you're 5'9" tall, you will regret it if you don't.
Razerr said:SunnyDay1 said:Razerr said:Now the frame size. I am 5.9 feet (+-181cm) I was thinking of the large variant.
181cm is 5'11" i think.
https://www.calculateme.com/height/convert-cm-to-feet-inches/181-cm
Still the medium?
SunnyDay1 said:Razerr said:SunnyDay1 said:Razerr said:Now the frame size. I am 5.9 feet (+-181cm) I was thinking of the large variant.
Still the medium?
You are correct, 181 cm is 5'11". I'm 5'9" and the medium works great for me. If the medium was any larger it would be too big for me.
Maybe another AM1000 owner will chime in on this post for you.
FREYebikes said:Hello,
Here we would like to share with all you how to use the gear set better.
Best condition use guide for 11 speed cassette and chain.
Green: best starting and riding level. The cassette and chain life is longest, and riding effect is the best.
Blue/Yellow/Red: under the speed showed in the graphic, cassette and chain is in the best condition, minimal wear.
Color meaning: Risk level of cassette and chain.
How about your use tips? you can share with us!
Map Paddy said:Hey I wanted to connect a thule chariot to the ht1000 anyone done this ?which thru axel adapter works and where did you find it
bugnut said:Well, My AM1000 was delivered yesterday. I put the bike together today and I have the battery charging. Hope to ride it tomorrow. Still needs some minor tweaking. This is my first ebike, so I am not sure how to adjust the shocks.
