Ambient2010
100 µW
- Joined
- Mar 5, 2018
- Messages
- 7
Is not the G510 released by Bafang even up to 60 volts?
Ambient2010 said:Is not the G510 released by Bafang even up to 60 volts?
nataS@phnet.fi said:Ambient2010 said:Is not the G510 released by Bafang even up to 60 volts?
Full charged 52v battery is around 58,8 volts.
Jebu said:Is possible to add a button to change the motor modes on the flight?
what about with waterproof?
Is possible to change the chainring or install a chaintset with a front derailleur?
3gfrey said:I ordered a 3rd gen Frey a few months ago. I have about 240 miles on the bike and almost a couple of weeks ago, the motor stopped working. I made a video of this and contacted Frey.
Ivy mentioned that she reached out to bafang rep and he is unreachable for the next two weeks due to Chinese new year.
Will keep you guys updated on how this gets resolved.
luna5k said:Would it be possible to have a list of specifications for the $2000 level bike?
Adova said:luna5k said:Would it be possible to have a list of specifications for the $2000 level bike?
Sure - I don't think they would mind as this is the same configuration I think anyone would get at this price point (at least at the time of my order):
Bafang Ultra 48V 750-1000W mid drive system with throttle;
48V /17.4AH battery;
ROCKSHOX RECON 150mm air suspension fork;
ROCKSHOX MONARCH rear suspension;
TEKTRO HD E725 4-piston hydraulic brake with power cut function for ebike use;
SHIMANO ACERA 8 speed group set;
CST 27.5*3.0" mountain tire, MAXXIS 27.5*2.4” available for option;
I added the lights and extra charger as well as the 21AH battery.
Z0RR0 said:Since we're talking design and versions and whatnot, I would LOVE to see you guys (or anyone) come up with a more modern geometry, with more head angle, and the signature "kinked down tube that premium MTBs have.
Essentially look at what Haibike is doing in terms of designs, but not quite as high-end and with the Bafang Ultra instead of the less powerful europe-compliant motors.
18650 said:Still silence about riding expierience (power, range)?
robocam said:What do you mean by "modern geometry?" The head angle is already relatively slack at 66.5 degrees. It's even slacker than that of the Specialized Enduro 29. What do you mean by "more head angle?"
What do you mean by "kinked down?" Are you referring to an S-shaped downtube? If so, what are its advantages? It seems that a straight downtube is a more logical choice for the battery. Maybe you can show a picture of what you're referring to.
Sduro Ultra said:I know this guide, but karls setting wont fit a standart ultra and lets lots of questions open in setting parameters
hoojsn said:Sduro Ultra said:I know this guide, but karls setting wont fit a standart ultra and lets lots of questions open in setting parameters
Yes Karl setup is not suitable for our standard Ultra. I didn't reprogram mine since the current setup is still suitable for me. Did your motor came with steel drive or nylon? Bafang sent me the replacement steel drive plus a new set of the display.
Sduro Ultra said:hoojsn said:Sduro Ultra said:I know this guide, but karls setting wont fit a standart ultra and lets lots of questions open in setting parameters
I did not open my motor yet, so i dont know. Should i open it? Is nylon bad? I got it from cnebikes.com
I lowered the shut off times and it worked well to get it more spontaniously. But i am not dosteelne with the programming
If you able to open, than take a peep inside, otherwise talk to supplier cnebikes. It will be good that they request the steel drive for you. Understand Luna, Frey and others bike maker come with steel.
Daxxie said:If you able to open, than take a peep inside, otherwise talk to supplier cnebikes. It will be good that they request the steel drive for you. Understand Luna, Frey and others bike maker come with steel.
Where did you get that information?
My Bafang Ultra Ludicrous from Luna has a nylon gear.
I asked them before ordering and they said their Ludi version has NO steel gear.
fechter said:Gear destruction is pretty dependent on motor temperature. If the motor stays cool, the gear can handle a lot of power without turning to peanut butter. The BBS02 over driven had a real tendency to do this.
We'll have to just see how the nylon gears hold up. If they start failing, I'm sure somebody will make a steel version.
hoojsn said:Why wait, when the steel gear upgrade were already available for free?
