Drop Dead Fred said:Hey q,
I believe you probably have an adjustment problem. While I prefer SRAM and it is mainly because I seem to knock Shimano out of adjustment regularly as they seem to be a bit finicky. Did you have a bike shop set your bike up? You might want to take it down to a shop and get a tune just to be sure and they will let you know if something is having an issue.
Fred
qqquent said:Jebu, do you know what caused this?
I'm also having issues with my AM1000 and think a worn out cassette is to blame. I did a rather thorough alignment of the derailleur last night and still have issues this morning. Hard to believe the cassette is already bad as this is only the third time I've ridden the bike. The chain skips on the two highest gears (the smallest cogs) when pedaled hard. It's bad enough that I can't use the highest gear.
Did you order a new cassette? If so, what did you get?
Hope this issue isn't ongoing.
Jebu said:The problem is that the swingarm does not support the force of the motor and it flexes. This causes the cassette to receive a lateral force for which it is not prepared.
You can test it locking the front wheel, the rear with a lot of grip and use the throttle. You can see how the swingarm flexes.
agedashidofu said:Drop Dead Fred said:Hey q,
Fred
Would it help to go easier on the power when changing gears? This motor has like 160nm torque - so with that kind of power, it would be really punishing on the cassettes i would imagine.
fechter said:Jebu said:The problem is that the swingarm does not support the force of the motor and it flexes. This causes the cassette to receive a lateral force for which it is not prepared.
You could get a lot of lateral force if the chain line was extreme. Probably a lot more than frame flex would cause.
qqquent said:agedashidofu said:Drop Dead Fred said:Hey q,
Fred
You’re probably right. Time to take it to a shop. I’ll let everyone know what I find out.
The issue is happening once I’m already in gear, pedaling with some resistance, the chain skips regularly. Especially bad on the highest gear but has started happening on the second highest as well.
DaninSpain said:I received my bike a few days ago and I discovered after a 5km ride that the nut holding the left pedal crank was missing, and hence the arm fell off. I cannot say whether or not the nut was missing or it was loose and fell off during the 1st ride, but what I do know is I cannot ride my new bike until I can source a replacement nut, which is not as easy as you may think. I visited 8 bike shops before I finally ordered it online from Shimano.
kerim said:Edit: Edinburgh Bicycles found me a new bolt! All sorted. I leave this post as a reminder to check your cranks before they fall off...
DaninSpain said:I have now completed 500 miles of a mixture of light trails and road use.
Overall, I really like this bike, I look forward to riding it and it makes me smile.
Here are a few pro's and con's (Ivy, feel free to chip in any time![]()
Cons:
1. Crank nut lost on first ride. Solved by ordering this:
https://www.amazon.es/gp/product/B019J4R54G/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
These don't undo themselves and haven't had a problem since.
2. My display is not waterproof and let's in moisture. The first time I washed it (carefully) I didn't notice until the next time I rode in the sun and it fogged up to almost unreadable. I did report the damage to Frey, but they have done nothing to remedy the fault. It's possible they forgot about me, but the fault remains.
3. The decals started to peel off the first time I washed the bike.
4. This is probably my biggest gripe, but I think it could be addressed with some clever software adjustment. When I stop peddling, the power continues for around a second and a half, which when you need the assistance to stop, seems like a lifetime, and it has put me in real danger several times. Apart from the danger aspect, when you release power to change to a higher gear, that gear slams into place because the motor is still working. In higher power modes it's pretty obvious it's not doing the transmission any good at all.
As a temporary work around, I have got used to touching the brakes (which cuts the power immediately) just before I change gear.
If anyone has worked out how to make the motor cut out quicker, please do tell
5. Throttle Range of Movement: Nothing for the first half.
6. I wanted to change the seat post for a dropper, only to find the AM1000 has an unusual diameter. I think this may have been addressed on the newer bikes, but that doesn't help me
Pro's
Don't get me wrong, I Love this bike, and none of the above problems are unsurmountable by FREY.
1. The AM1000 gets A LOT of attention out and about. This is good, but bad as well because of the bike is illegal to use on public highways in Spain, so prefer to stay under the radar..... But it just looks so badass lol.
2. The power when climbing in a low gear just blows me away, every time. For me this is the biggest smile factor. I never get used to it
3. The Throttle is great for when I come across something a little too technical for me (doesn't take much), I know I don't have to worry about pedalling.
4. It's fast and practical: I can happily cruise along at 30mph on level 5 (sport mode), which means with the rack and panniers attached I go to our nearest shopping mall, 15 miles away pretty much as fast as I can in the car.
5. This one was unexpected, but I get more exercise on this than I do on my regular mountain bike. I think it has something to do with effort and reward. On this bike you put the effort in and you are rewarded by speed and a super powerful feeling...which makes you push even harder. Whereas, on my non assisted MTB, I would put in huge effort and not really reap the reward that I felt was justified by that amount of effort. Anyway, needless to say, my average heart rate on my rides is around 177bpm. Pretty high considering I'm 54yrs old and on a "cheating" bike.
Hope this has helped anyone thinking about buying a Frey AM1000.
DaninSpain said:4. This is probably my biggest gripe, but I think it could be addressed with some clever software adjustment. When I stop peddling, the power continues for around a second and a half, which when you need the assistance to stop, seems like a lifetime, and it has put me in real danger several times. Apart from the danger aspect, when you release power to change to a higher gear, that gear slams into place because the motor is still working. In higher power modes it's pretty obvious it's not doing the transmission any good at all.
DaninSpain said:Fechter, your last paragraph about the throttle; you lost me after the first line :lol: I need to borrow a Windows PC to adjust the settings as I'm a Mac only dude. When I get around to it I will get the software up and running to look at the throttle settings. Anyone done this yet to lessen the dead area?
Thanks again.
Dan
DaninSpain said:Thanks a lot Fechter. It's very much appreciated that you took the time to illustrate that for me.
I'll blag a Win PC from someone and give it a go.
Adova said:[...]
I am a software engineer and plan on trying to see if I can port the software over to Android so that it could be modified on the road. Just need to make some sort of Bluetooth adapter for the cable.
I'll try to update as I go along...
18650 said:Does anyone know, can the throttle be (easily) removed?
hoojsn said:Curious, I don't recalling there was a Max Ultra 500watts. Bafang Website shows MM G510.750/1000. both 750/1000watts are actually the same.
If 500watts, I will prefer the new M600 which are much lighter in term of weight and stealth looking.
