.. a mini review.. have only spent a few days and approx 100km riding it, so a grain or two of salt may apply :lol:
Essentially this is my first owned e-mtb but I have used friends (lower powered) bikes on the trails so I have something to base judgment upon.
First off, this bike wins no weight contests! I weighed it (with the 21ah batt) at a tad over 31kg. My neighbours specialised levo is around 24kg, so the 1000 at standstill feels quite the tank in comparison.
However, given the dollops of power on hand the incredible mass of the bike becomes a bit of a distant memory. It pulls and does so with aplomb in most gears. Most euro and US bikes are limited to 25kph (without hacks) but the 1000 quickly exceeds these speeds and there is a real adrenaline rush when doing so. Pedal assist is generally smooth, but definitely not up to the refinement of the current commercial offerings, it feels like it's either on or it's off. The bosch and shimano drives seem to have a proportional curve that feeds power on far more gracefully. The drive is also incredibly noisy in comparison and there's no fooling bystanders or other bikers that you are not riding under your own steam...
Efficiency... unless you are lazy, the bike can PAS comfortably on eco1-3 all day long. My bike travelled nearly 25km's on varied hilly road at an avg of 17kph and used only 10% battery. However I'm only 65kg so that played a big part no doubt. Sport mode is well,just what is says... tons of power applied quickly and aggressively. And it shows by chewing through the battery. Great for getting from A-B as fast as possible regardless of what stands between, and perfect for showing (scaring) friends who have never experienced an e-bike before..and even some that have.
Having owned an FS Kona for many years, the 1000 seems to handle quite well on the track, although its a bit 'crashy' underfoot and less predictable because of the weight. More experience needed in riding trails with this but I don't think it would keep up with some of the brand name e-mtb offerings because of the higher CG due to the big battery and heavier frame overall. But given the loads of power available this inconvenience can easily be forgiven and it's genuinely far more fun on the less technical parts of a track, blasting past a 8k levo on a straight bit of dirt is absolutely grin inducing
But certainly won't win any prizes on the tight twisty bits, and largish jumps seem to be a little like wrestling a bear in zero gravity, this is a lot of bike to try and straighten if things go a bit skewiff.
It's also a great bike just for cruising,and even my partner who is not an avid rider loved the stability and effortlessness at covering distances quickly. She was initially terrified but quickly got the hang of it, so much so she left me behind on my normal bike quite a few times
Overall, I think this bike for the price is a fairly good compromise. I certainly wouldn't pay for (or be able to afford) an electric specialised, trek or giant at the moment. So, the AM-1000 fills this gap quite nicely. Yes, it's a bit crude and crass and will most likely upset the 250-350W snooty brigade on the trails with it's noise, speed and industrial looking engineering. But so far it's been the best fun I've had on 2 wheels in over 30 years of riding.
Well done Frey.
Well done Frey.
