This a 500-5m (I think it's 15mm wide) belt that was "Made in Japan" and originally meant for a 200 watt scooter. I was probably pushing 1200 watts through at the time it broke and it broke accelerating full throttle from a dead stop. Now, I'm not sure why it broke. About 1/3-1/4 of the belt was hanging off the wheel's timing pulley (Sprocket like thing that's meant for belts - just a heads up because I didn't know what a timing pulley was until about 6-7 months ago) since it wasn't completely aligned and the belt was under moderate tension.
Do you think there's an upgrade I could make that'd make it nearly indestructible? I can't really increase size dimensions much since the timing pulley is built into the wheel and I'm working with a tightly fitted space to begin with. Do they make "Kevlar" or some other material type of belt that's clearly superior to this one?
Also, on a possibly related note, the motor's shaft doesn't tightly fit against the timing pulley attached to it, so I found out that it "bounces" up and down by a little bit as it rotates which is the source of this irritable clicking I've been getting and it's probably been the cause of past clicking. Is there some sort of fix for that? Like maybe a "filler" material that can make the shaft held securely against the timing pulley's inner walls?
Thanks everyone! You all have been really helpful in that past with your extremely valuable insight and experience.
