mvadventure
- Joined
- May 2, 2007
- Messages
- 419
Batteries: Aten Energy LiPO4, 48 volt, 20 AH
OK, here is the deal: Today, in the rain, a light rain, a mile from the house my battery quit. Prior to quitting the battery was reading >52 volts and had been used only 15 miles. When everything stopped I glanced at the watts up and had dropped to 22 and then was dependent on how fast the front wheel was turning. As I slowed down the voltage dropped accordingly.
Since I don't use a fuse I immediately checked the connections and all were watertight and in good condition. Turning the key on and off allowed the red throttle light to come on but that's all, not even the watts up meter. So, much to my chagrin I pedaled home. I didn't like it, the bike is heavy, it was raining, I was wearing LOTS of rain gear and very tired.
Once home and in a dry garage I looked at the battery and all appeared OK. I pulled the connectors off the red and black leads from the battery and got 18.6 volts, the black lead comes out of the BMS. The battery tops are covered in a piece of Chinese bakolite or something to which a solid state thingamajig is taped with about a bunch of wires going into it through four multi wire pins, all from the battery. I removed the top of the thingamajig and sure enough there is a circuit board, some stuff that looks like toothpaste smeared over part of it and a couple pieces of metal (aluminum most likely) that had stuck to the top of it. Despite the toothpaste looking stuff everything looked OK, nothing burnt but I'm not sure about those pieces of aluminum so I merely put it back together the same way it came apart. Then I checked each cell and all was well and put my meter back on the red lead and directly on the negative lead and got 52.6 volts. So, the battery itself is good.
Putting a meter on the charger connection gives me 18.6. A thorough visual inspection shows no broken or burned wires. When I reconnected EVERYTHING the red throttle lot comes on, the controller (48 volt 40 AMP) light comes on but the watts up remains blank and there is not sufficient power to get the wheel to turn.
I have not taken all the wires from the controller to the wheel apart as I don't think the problem is there. I think it is in the BMS and am searching for opinions and ways to get my bike running again as I need it Monday. Had this happened yesterday I would have been screwed as I was 15 miles away at one point. Not even Lance Armstrong can pedal this beast 15 miles.
Calls to Aten Energy have yet to be returned but in their defense it's only been a couple of hours and it is Friday evening on the East Coast. Who knows what time it is in California.
Mike
Mike
