I do not know how or when it cracked but I noticed I have had to tighten my shock bolt every ride as it came a bit loose. Today when I was riding I noticed a weird noise and tried flexing the rear tire and noticed play in the shock. Then I noticed a crack on both sides where the shock bolts to the frame.
IT seems to have cracked at a weak point. I do not think much forces get pushed on that crack and that is why I am able to use my bike with the crack.
Is there anyway this can be fixed or is the frame shot? I am looking for any ideas to try and reinforce this, I do not care if I have to scrape away paint or make an ugly fix. I do not think it is a very high stress point so hopefully something can be done.
I figure I will just use the bike if it can't be fixed as if the shock came loose I figure all that would happen is I would bottom out if the shock somehow got dislodged?
