1000 Miles In - JoyKie 350W 36V Mountain Bike Review (Risky Cheap Chinese Bike Purchase)
jetpackjbd
Lithia, Florida
I’ve had this bike for about 10 months now which I bought on Amazon for $450, $550 with shipping. I’m not even sure what it is and can’t find it anywhere else, it was listed as a HILAND ROCKSHARK but has no Hiland logos on it. The sticker underneath it says it’s manufactured by JOY KIE TECHNOLOGIES, but even then it’s hard to find my model online. Apparently it’s a “Model: ROCKM007 gy-75A455-350WA”.
Amazon Link
So, even though you probably won’t be buying this model anywhere, this review should apply to a lot of cheap Chinese eBikes:
Quality: It’s fine. The welds are kind of ugly but seem strong, most of the parts are off the shelf from brands I recognize, and nothing major has gone wrong. The shifter arrived with a crack in it but was still functional, and I used it for about 400 miles like this. Their support is terrible though, I tried to message them at one point about the broken shifter and got no response, they likely only deal with Chinese customers. Maybe my email got flagged by The Great Firewall. It’s a $20 part, whatever. Battery is holding up fine and hasn’t even gotten warm. No squeaks yet! (outside of the things I installed on the handlebars myself).
Repairs Done: Most of the repairs are from general usage or my mistakes. I’ve had to adjust the shifting a few times, the brakes need adjustment every hundred miles for some reason, and the tubes have been replaced numerous times. More “major” repairs were my fault; I got my chain all tangled and ending up cutting the shifter cable to fix it while trying to replace the rear tube. The front wheel bearings failed recently which might’ve been my fault, as I had loosened them at one point to reapply grease (they never seemed to move as smooth as a new bearing should) and I don’t think I tightened them enough, causing a bearing to chip and the balls spilling out of the races. My biggest issue has been the brakes. They fail in some way roughly every 100 miles. Currently, they’re both a bit loose and the rear brake spring “skips” and releases if I brake harder than it wants to. One day it’ll be looser and skip, the next day it’s mostly fine. I have to take apart the brake calipers to fix the skipping by reseating the spring and adjusting the screws. There’s a bit of a wear mark inside the caliper from where the spring skips but I don’t know what was causing it to do so in the first place. Replacing the caliper would fix it I’m sure, but it’s still annoying to have to replace something that failed after ~400 miles. The seat ripped too, but it was uncomfortable anyways and I had had the bike upside down on the dirt so it’s mostly my fault.
Advertised vs Reality: The listing claimed a range of 30-50 miles with pedal assist, or a range of 26-40 miles with throttle only. That’s misleading, although I will say the range hasn’t gotten much worse in 1000 miles. It’s more like 20-30 miles with pedal assist if you drive reasonably, and 10-20 miles by throttle only. It’s still more than enough range for me but it’s something to be aware of. I go about 3 days between charges, riding ~6 miles each day. I could squeeze a bit more range out of it but I’m trying to preserve the battery life by not fully cycling it. The speed claims are actually accurate though, if not understated. They claim 21MPH throttle only, and I’ve gotten up to 22MPH throttle only (wow!!). They also claim 25MPH with pedal assist, but that depends on many conditions like the driver’s strength and terrain. I’ve gotten up to 35MPH once going down a steep hill pedaling as hard as possible with full assist (weak numbers to some of the people here, I know), but typically the most I can do on normal land is 23MPH or so. The trails are twisty here so I only choose to go about 17MPH if that.
General Complaints: Besides the brakes that love to fail, I have some other annoyances with the bike. First off, the pedal assist lags by half a second. Maybe it’s normal for it I have a delay for “safety”, but in my experience it’s annoying and a little unsafe. Not only does it take half a second to turn on once you start pedaling, it takes half a second to turn off when you stop pedaling. Luckily the brake sensor cuts it off with very minimal delay, but it’s still a little concerning. I should also mention one of my brake sensors came unsoldered, but since I turned off pedal assist it favor of throttle-only I haven’t bothered fixing it. Controlling the assist manually with the throttle is a more pleasant experience. Another annoyance is that only one color option of the bike came with a headlight, for the same price. I didn’t notice until after I bought it, so I don’t have a headlight (but I still have the ability to turn on the absent headlight by holding the up button). I might be able to add one, but I haven’t needed to open it up and have an excuse to find the connector. I think the controller or display was originally designed for SLA batteries, as the battery display is very misleading. The battery chart decreases with voltage drops and rises when unloaded again. It doesn’t really show until the charge is below 70% or so. Thankfully there’s a voltage readout as one of the menus, otherwise I wouldn’t trust it. 3/5 battery only shows at 36V and below according to the meter, and only goes into 2/5 at around 33V.
Positives: It’s a great first eBike if you’re on a budget and don’t mind doing some work every so often. The other cheap eBike brand at the time was “TotGuard” at a slightly lower price, but the main reason I chose this instead was that I didn’t want a name that means “Toddler Protector” on my bike.
-As an eBike, it’s somewhat discreet as the battery isn’t sticking out, it’s inside the frame. The thick frame, wheel motor, and controls give it away, but it’s not obvious at a glance to someone looking for e-bikes to steal (I hope)
-In my case, I think 350W is the sweet spot, as I don’t need to go fast on our twisty roads and I don’t need more power for gravel or dirt roads. It can keep its speed up hills too, peaking at around 17MPH. It doesn’t like going up hills; I can hear the motor strain and see the battery voltage drop, but it’ll do it.
-It’s surprisingly quiet, motor noise is audible but the tire noise is louder. Even so, my dad’s new-ish road bike is louder to the driver than this bike is with a motor and fatter tires.
-Even if it was just a normal bike, this would still be the fanciest bike I’ve ever owned. It’s got an easily adjustable suspension, disc brakes, and a thumb shifter, which is a step up from my previous 4 bikes.
-It’s reasonably comfortable. It only has basic front shocks but it still manages to absorb the feeling of cracks in the sidewalks. You still feel big bumps like a 2 inch gap in the sidewalk or going over a curb, but I think that’s standard with almost any suspension. The big tires alone do a lot of shock absorption, especially at lower pressure.
-It’s built pretty well. Nothing stands out to me as a design flaw, just some cheap parts. They cheaped out on the right things to save money without affecting much of the user experience (except brakes, grrr…).
UPDATE: At ~1200 the throttle started cutting out and giving me an E08 code each time. I tried replacing it twice and neither worked, giving the E08 code the entire time as if they weren’t hooked up, or they were giving lower values than the original one. I broke the original one trying to look for loose wires inside, so now I don’t have a working eBike. The manual says it’s a hall sensor error, but I’m pretty sure that’s because the throttle uses a hall sensor. At least I hope that’s the reason. So I’ve been stuck with my eScooter and normal bike for a few weeks. I’ll fix it at some point, hopefully.
Update 2: I eventually got around to fixing it, the issue was the cable connecting the throttle connector to the motor controller, but unfortunately I already bought a new motor controller before figuring it out. I made a new cable for it and got it working again, but it came undone. New motor controller has more features but doesn’t have a wheel speed readout and feels slower. I’ll try the old one again.
I also got some free hydraulic brakes which I’ll try installing onto this POS. Should hopefully be more reliable than the broken mechanical ones, although the hydraulic ones are broken too (I have the repair kit)
Well-done detailed review! :bigthumb:
You have identified common BSO substandard quality issues with the hub bearings and brake caliper inability to achieve or remain properly adjusted. High probablilty that the next components to experience similar issues (failure or inabililty remain properly adjusted) would be the BB and suspension fork bushings.
The low price point is universally appealing but actually false economy if you plan to keep the bike for an extended period or ride it often. It will require several component upgrades to reduce user frustration and increase safety.
Curious as to how the battery holds up...
PS: The front hub bearing issue may not be user error. ;) Oftentimes, lower quality hub bearings can be impossible to adjust correctly for the required free-running/minimal play. Or, once adjusted correctly, will not stay in adjustment.
I'd replace it. A bad failure there risks high injury to the rider.
That's assuming they're "real". I'm pretty sure there's plenty of counterfeit parts out there of every brand of every type of item you can imagine, even though there's seemingly no point to counterfeiting cheap stuff, it happens anyway. :/
That's actually the Mr Potatohead company, guarding you against unsafe tatertots. ;)
I've seen this kind of thing in different ways when a battery is one series cell more or less than what the meter was setup for. (14s battery on a 13s setup, etc). Sometimes there are menu settings for this, often there aren't.
That's unfortunately common with cadence-type PAS controllers, partly because of software design, partly from hardware constraints. Some of the delays are much longer than that one.
Even the cycle analyst (best of the cadence-PAS response times I've seen) has some short delay responding to the cadence sensor simply because it takes time to count pulses from it as it spins. (the more magnets on the sensor disc, the less delay there will be)--but if you pedal backwards even a teensy bit it instantly stops sending the signal to the controller (or activates regen braking if you turn that option on). (also, the CA does actual cadence control, not just on/off assist levels, so you can use the pedals as a throttle)
Thanks!
The BB hasn’t given me any signs of issues, I think that’s going to outlast the frame. At least I hope so, as I don’t have the tool to replace it…
Something in the suspension may be going out, not sure what though. It doesn’t fully bounce back when unloaded unless I push on it, giving me less travel than it should have. I’ll try oiling it for now to see if that loosens it up a bit.
I’m hoping the battery holds up quite a while, it should only have around 80 cycles so far. I’d expect it to theoretically last another 10 years if I do 1000 miles/80 cycles a year. Good LI-ION cells should survive well over 800 cycles, right?
Ten years is pushing it. Realize that they age and deteriorate just sitting on a shelf. Some cells are better at chronological aging effects than others.
Some thoughts:
Does it have bearings in the suspension and spring pivots, or just bushings?
Are the bushings metal, or plastic?
Are the pivots correctly aligned with each other? (so that both sides of all the pivots have the identical axis of alignment thru them; if they don't the bushings/bolts/pins could bind; at least till they wear-in).
Possibly, but I wouldn't expect there to be good cells in a pack that comes with a bike like this. Probably not bottom-of-the-barrel like the recycled-garbage-cell packs some places sell, but probably not great ones either.
Also, has been pointed out, calendar aging (even if the cells are never used) still occurs, so combining both time and usage will age the cells "more thoroughly".
I purchased a set of Shimano 200 disc brakes from Amazon for $60 and (even if they're knock-offs) they work great (This was a year or so ago). Also,I saw a set on Aliexpress recently for $30, but I'm anti-Ali (check Berm Peak on YouTube if you're interested).
Good to know, they haven’t had any issues like frequently falling out of adjustment? It’s possible that the reason my brakes keep coming loose is that that I haven’t tightened the cable screw enough, but I’m afraid of cracking the cheap aluminum casting.
I haven't needed to do anything in the year or so they've been on the bike. FME, hydraulic brakes need to be bled occasionally, but not until they feel "spongy" or the lever depresses too far before they're activated.
These brakes still function perfectly on my MTB traveling downhill at up to 35 mph. The bike is < 30 pounds which is a factor, but I'm 175, not exactly lightweight. They haven't required adjustment. I have a pair on a Giant enduro bike that function perfectly (for me) too.
This bike is fine for a guy like jetpackjbd, who can repair a broken throttle wire, repack bearings and do all the stuff he did. I can appreciate how people in the business disdain BSO's, but like the guy said, his ebike was still nicer than any he ever owned.
I bought MT200's originally for about $100 a pair, and now they're less than half that price. I bought a set for $55 and it looks/works the same.
absolutely, false economy, I agree. how much is this bike after years of replacement parts, like front axle, BB, brakes, etc..
everybody tells here how much was the bike, but how much he spend on it over years.
cheap parts do not last.
but, but educational aspect is here.
False economy? Doesn't look that bad for the author. Well known brands with decent components also require part replacements, and they tend to be expensive. I'd avoid buying a bike with an assumption that i will replace everything but the frame, but if you can ride it as is and just replace the parts as they wear out - then all is fine, these parts would have to be replaced anyway no matter how much the bike cost.
Also, i noticed many well-known and well-respected brands switch to using cheaper parts. The bike still boasts the logo, all original branded components, but low quality bolts and nuts are used, lower quality bearings, you know - all the parts that you don't pay attention to. Front bearings in my new roadbike seized stiff after few rides - water got in and they rusted. While my old MTB has been frequently soaked in water and mud over many years and i don't even know what bearings it has - there was no need to check on them. Some nuts are rusting on the roadbike, but not on old MTB..
tens of Wallmart bikes thrown to the garbage after 2-3 years of use, here in Canada, I saw it in my own eyes when I went there
wallmart bikes are China brand bikes.
I belive in what I see in the dampster, was there many times,
but what people write????. is cheap for the reason, right?
on other end you have brands like ChrisKing bike parts maker - they last lifetime.
tens of post here on people buying cheap bike and start upgrading right away, right?
I’ve needed to spend very little on the bike, though I have spent more on personal errors. When it was fairly new I paid $100 for someone to help fix my dumb mistake of tangling the chain while replacing a tube, and they did some brake and shifter adjustments. I think I’ve spent around $75 in parts on a new shifter as the old one came cracked and I broke it trying to fix something else, and on a new motor controller that didn’t actually need replacing.
If I started off owning it knowing I’d need to get used to doing some repairs, I could’ve still spent $0 extra on it. The bearings I replaced were technically free too, they came out of a lawnmower pulley I found out in the woods.
A cheap bike will never compare to a higher end one though. I don’t expect to be junking this anytime soon but it wouldn’t be worth much if it didn’t have a battery.
Yep, buying tools to do the service yourself is the best way to reduce cost. Regarding the throwaway Walmart bikes - well, if a bike costs $200, and servicing it after a year or two of neglect is also $200, then you just throw it away...
Finally got the hydraulic brakes functioning and was about to test it out on a ride, but forgot the front wheel bearings were bad. Just from sitting they seem to have gotten worse. Took them apart to find even more metal chipped off.
Ordered new parts on Amazon, thankfully it’s standard. Once again showing potential problems with cheap bikes.
I am far from knowledgeable on bikes as I just bought my first one in 40 years I last road as a young teen. But I am pretty decent with basic mechanical parts and things. My point being is that bearing race looks like it was cast in what we call pot metal. You know the same stuff 70's car door handles and other cheap parts where made. Never saw parts that had rapid rotation made with any before.
It seems to be steel- just low quality and poorly hardened. It wouldn’t surprise me if it was made of various bits of recycled scrap though. My new bearings arrived so I might try to take a torch to these and see if it melts easy.
1200 Mile Update:
The bike is back in service again! Front bearings were replaced with new ones and I now have quality (but poorly repaired) hydraulic front brakes! I put the old motor controller back and redid some wiring, and now it’s finally ready for daily commutes again.
I was worried about the battery degrading while not being used for half a year, and it appears I may have been right to be concerned. The range seems to be worse and now the top electric speed is a few MPH lower. I wasn’t going full speed when I would ride it every day, so that might explain the range difference on my test, but the lower top speed even at full charge is concerning.
While not in use, the bike was left at 2/3 SOC and wasn’t charged at all, as I believe it’s bad to keep Li-ion cells constantly charged and at 100%. Is there something I could’ve reasonably done differently to preserve the battery?
I’m not too concerned about the battery degrading since I only expect to be using the bike regularly for less than a year more. I hope to get a job soon, and it’s not likely to be biking distance away. Still sucks that it isn’t surviving as long as I wanted it to. Maybe I’ll try rebuilding the battery pack at some point.
I owned a Chinese cheap fake emtb as well, different brand but lots of same('ish) parts. Elleglide M1.
Couple of issues:
Assembly was bad, needed to go over every nut and bolt.
Came with some dmg to one of the cranks, can't remember exactly but I got a partial refund so I could get a replacement part locally.
Thing is, all those advertisement pictures showing those bso's on single track or even rough gravel with lots of bigger rocks and potholes, the advertised 'hydraulic suspension' will last you a single day.. but hey, you can order the complete 'suspension fork' again for 67 euro's.. except that the real value of the thing from an OEM supplier is less even...
No real suspension fork can be that cheap and still be reliable. It's just not possible. And almost all of the cheap CN 'embt's' use this same front fork.
The positive surprise for me: rated 36v 250 watt, it took a 48v battery no issues ( which also increased the top end speed by quite a lot ). KT controller/screen like all the cheap stuff, but electrical wise I don't think it was as much a pos compared with the mechanical prowess of the 'bike'.
Imho, these bso's shouldn't get sold to normal consumers, they will end up as landfill material within a short time. Also, the Eleglide was around the same price shipped, little under 600.
Later on, I bought a second hand Giant Talon, a tsdz2b and a battery latter two through pswpower. I planned on using another bike, couldn't because bb was rusted in place and even with powertools ( grinding wheels ect ) I wasn't able to get the old bb out to facilitate placing tsdz2b, but if I had been able to use an existing bike I would have been a lot cheaper going aftermarket conversion. Now it was only a bit cheaper.
And I still ended up with a vastly more capable bike ( I can and do ride single track with it, namely Schoorl/GMA mainly for any lost Dutchies in here ), with an actual frigging mtb suspension fork ( still an entry one, but even a Suntour XCR 100mm airfork will not kill me when I go off drops ... and offers vastly better riding quality ). I have double the range, at least, a better bike and it was cheaper to DIY.
That's the issue I have with all those cheap bikes, the value isn't there because of the bad component choices like others been pointing out.
Even as used as pure commuter, never taking it off road, that suspension fork wouldn't even survive some potholes at speed it just wouldn't they are as I would describe a POS.
It's just the lowest cost components they can find which they think might pass for acceptable at the price point, and you have no local support. Which is fine, if nothing breaks.
tl:dr imo cheap CN ebikes, especially those you buy without any local support, are in 99% of cases a money trap which will not save you anything in the longer run. DIY is cheaper, gives you more control over parts and thus ability to pick higher grade one's ( though this depends 100% on your used bike market in your region, as getting a good bike for a good price to build off is key ).
edit:
You'll end up using the lockout to get it to behave like a fixed fork eventually. That's how all those 'suspension forks' end up. The issue will be in the leg with preload adjustor, that's where your spring is the other side is just lockout ( and on actual suspension, hydraulic damper with rebound control ). But these bottom on the barrel 'suspension forks' are not user serviceable really.
I would look for a second hand entry level mtb suspension fork, even the cheapest SR Suntour XCM coil fork will behave better and will be just as expensive as getting a replacement for that thing you have now.
edit:
The suspension is somewhat-serviceable on this, actually. But like most cheap bikes it’s not hydraulic, it’s just springs with some rubber dampers which might seal a little bit and give a slight pneumatic cushion. The fork is either pressed or welded on; it doesn’t seem like it’s intended to be replaced.
The travel is really long and with a little bit of modification I could make it a low rider in the front, just removing the spring does this. Not really useful but it’s something to note.
Also, about your 48V comment, the motor controller on mine and probably yours is interoperable and has a setting in one of the menus where I can set it to 24-36-48. See if you can change it on yours and the battery indicator should work correctly.
