Hi guys. I finally got my battery!!! Its just too bad I don't have a bike to test it. This is going to go on my front hub 406 what do you guys think about it? Also would this be good enough for a 5 series motor? Thanks.
Specifications:
Fit 48V Motor Wattage: 500 Watt to 1000 Watt, 700 Watt suggested
Voltage: 48 Volts
Capacity: 15 Amp Hours
Dimension: 16" X 6" X 3"
Weight: 15lbs
Charging Voltage: 61 Volts
Charging Current: <5 Amps
Rated Discharging Amperage: 15 Amps
Max Continuous Discharging Amperage: 30 Amps
Maximum Discharging Current: 60 Amps
Discharging Cut-off Protection: 35 Amps
Lifecycle: >1500 times
Includes :
1x 48v15AH LiFePo4 lithium-ion batteries
1x SUPER B.M.S System
1x 3 Stage Fast Charger
Specifications:
Voltage: 48 Volts
Weight: 15lbs
Includes :
