rollingreenhills
1 W
I am about to swap out the drive system on this cargo bike of mine which I was a bit disappointed with.
This is my first ebike build, and I have learnt a lot, the biggest ones are that torque is very important, and that 24 volts is not great owing to high amps required to up power. Correct me if I am wrong.
The original design was to have a rear wheel driven bike, but this caused all sorts of problems. So next up I mounts the motor of the front of the bike, which works fine, but the bike usefulness is limited by the lack of torque provided by the motor, which is only 9.7nm. . .
I have in the post a Bafang BPM 48v 500w which I hope (and expect) will be better.
Here are some links if you are interested:
Building the frame: http://dorkythorpy.blogspot.co.uk/2015/08/diy-long-tail-e-bike-chapter-2.html
Front wheel drive method: http://dorkythorpy.blogspot.co.uk/2016/01/chain-driven-front-wheel-drive-ebike.html
Trike Conversion: http://dorkythorpy.blogspot.co.uk/2016/01/thorpys-guide-to-bicycle-sidecars.html
