Mystery motor cabling
Boatbike
Money4bike
I’m about to replace (hopefully) or repair a damaged motor cable on a Mokwheel branded bike. The cable connector type is unusual, though it appears very robust. Cable is hardwired from a Kyesang controller to a 750watt hub of unknown make. Mokwheel will not supply the cable. The connector is stamped Mutual, and their company website calls it an F-L915A. A supplier on Alibaba calls it a JH30 cable.
Does anyone know a source for a single cable (male end or extension cable) like this?
In a worst case, if I had to replace both the motor side and the controller side with a different cable/connector standard, which type is best?
Depends on your specific usage case (environment, current, number of signals actually used, etc) and how much work you want to / can do, tools you have or are willing to buy, etc.
A quick google on the p/n you give
shows at least one source for an extension cable that you can use whatever part of you need
$36.59
$34.94 each, ≥ 3 pieces
· Free shipping over $10.00
· Fast delivery by Apr 24 - 29
· Delivery guarantee
$1.00 coupon code for late delivery
· Free returns within 90 days, no questions asked
YLS L915 9 pin Waterproof Connector Screw Locking Male Female Motor Cable L=1000mm​
4.3 4 Reviews ౹ 29 sold
Color: L1000
L1000
Product sellpoints​
  • 1.9m To Ft|Connecting Extension Cord|Waterproof Screw Locking Connector:Features a waterproof screw locking design, ensuring a secure connection in any weather.
  • Versatile 9 Pin Configuration:Equipped with a 9 pin configuration, this cable is ideal for a wide range of electric bicycle applications.
  • Durable Alloy Construction:Crafted with a robust alloy, this cable offers long-lasting performance and reliability.
  • Extended Length for Flexibility:At 1000mm in length, the cable provides ample reach for various motor and gearless motor setups.
  • High-Quality Wire Section:Features a 3x2.5mm+6x0.2mm square wire section, ensuring optimal conductivity and durability.
