Hello everyone,
I am working on a project to design and build a small hybrid vehicle.
The design will be to run two PERM PMG 132 electric motors
with the followings specifications:
1) 72 volts
2) Maximum current of 400A (continuous current of 220A) - 200A peak
current per motor (110A continuous current per motor).
3) Be able to run at maximum power (72V and 400A) for at least 10 seconds.
4) Weight is of concern (preferably under 50lbs)
5) Cost is of concern as well (Preferably under $2000)
I have been searching for a battery system that can satisfy these needs but it is difficult to find batteries that can discharge at this rate.
Could anyone recommend a battery system (or combination) that would be able to satisfy the above requirements?
I have been looking into NiMH and have been leaning towards this chemistry as it seems to be the simplest and cheapest.
Has anyone had any success using small NiMH cells in series (such as hobby D cells) to power high power motors? Or does anyone know of other suppliers that have high discharge NiMH batteries?
Or could Lithium based batteries be the only solution here. (I'd prefer to stay away from these due to the cost and need for a BMS system - which would be required).
Thanks in advance for any replies,
Mike
1) 72 volts
Mike
