isthatvinny
10 µW
this is my sleeper powerwheels build, it currently uses a kelly KVD7215ND controller, MY1020 3000w motor and a 5ah 60v SLA pack. the battery is awful i know, but i bought the current motor and controller off marketplace and guy gave me the battery, im cheap and impatient so its in there, for now, just to get it going.
so first obvious upgrade is battery, ive priced out some large batteries with thoughts of the QS165 motor and larger kelly in the future and the largest i can fit i one space is a 60v 75ah, 120a continuous battery from Amorge that weighs about 40lbs using 18650 batteries. this is a decent choice but unfortunately with my obvious size limitations that would have to be mounted rear of the axle along with the large QS motor. yes i could go smaller in size of battery but were out here doing hoodrat shit with my friends and need the extra sauce in the tank for quick getaways. also with the kind of power going into this id only do wheelies.
this is a lot of rear weight along with me sitting almost directly atop the rear axle. id like to try to disperse the weight for better handling especially when the cart has drift rings on it. the cart has a full steering rack and pinion not a pitman arm so it gets great angle and the hand over hand steering feel with tiny powerwheels steering wheel is hilariously fun.
other smaller areas around the cart include 3 inch tall space full 16 inch width of frame under the seat from axle to steering collum, under and forward of the steering collum between my legs 4 inch wide 6 inch tall 6 inch long and then the last is about 3.5 inch wide,11inch long and 13 inch tall in front of the pedals. the largest is the area rear of the axle that the 60ah would fit is 13.5x7.5x10
in my mind i have some choices with all this room for activities
first thought is get a large number of 60v 1P packs with individual BMS and just stuff them wherever i can, wired in parallel. This seems reasonably easy to wire, safe and with a custom manufacture like Amorge i could get them in various shaped configurations. this could really help weight distribution as the light weight controller, living for now under the seat, could be relocated to rear of the axle for the heavier batteries to take its place, and other batteries even in that space forward of the pedals this seems like it would be more expensive than the 60ah pack but to be honest I thought this cart would cost me a few hundred bucks and im already a grand into it and have no regrets, why stop now.
other thought was the lug type 38700 lifepo4 batteries, these have insane discharge rates and with this extra space i feel i could packge them either in a large series parallel string going to all areas of the cart with a mother BMS overseeing all. this of course seems like a wiring nightmare and could be very dangerous as more wires is more opportunities for shorts. i have experience with DIY packs but none is the design of a pack built into a EV frame so it could be challenging and require modification but again possibly worth it for very nice weight distribution and versatility if and when i decide to modify the cart again for the other ideas and additions i have (i could write you a book on all the stuff ive done so far and whats to come, its far to much to put here)
third option is to use larger P induvidual packs spread out, same idea as the first just less induvidual packs, less wiring and hopefully less money. per haps 4-6 batteries at 3p. hardest part would be to figuring those packs cell configuration to then pass on to the battery manufacture.
let me know what you guy think i appreciate all the help i can get!
i dont take alot of photos so if your clever youll see in the pic the cart wasnt done yet. its very nice now with full lights w/ blinkers and reverse lights, quick release original powerwheels steering wheel, original dashboard all done up with battery monitoring, speedometer, switchs for lights, key, motor temps, ODO, trip, original powerwheels fm radio w/bluetooth added, original powerwheels shifter for F-N-R action, flip up oldschool schoolhouse chair seat, extra speakers for the radio added, drift rings, front brakes on order awaiting arrival, handbrake for rear coming soon its the foot brake right now, doors still work, trunk still works, seatbelt, custom frame i made to fit inside it, 65 degree from center steering with rack and pinion for big car hand over hand feel, i could go on but ill kill you with the details
yes its for adults, im a 27 year old 5' 10" asshole and hop right in there with room for your sister
