Need advice ford escape nimh
Jae
Ma
Hello, i have a ford escape nimh hybrid pack i can buy tonight for 50$ but i Can't find much about using them with solar. I would want to use them for a 12v system with about 200ah. This is new for me so I'm having trouble finding any way of charging and using these. Any advice would be greatly appreciated.
Nimh is NOT good for putting cells in parallel. I don't know what the capacity of the Ford cells are, but likely much less than 200Ahr.
The problem is when Nimh cells reach full charge, the cell voltage drops slightly. This causes the first cell group to get full to start hogging all the current and can even pull current from the other cells in parallel. This results in overheating and possible fire.
There are ways around this, but they are all cumbersome. It would be much better to find some LiFePO4 cells, which play nice when put in parallel. I have some modules that came from a Fisker, that all had one or two bad cells. These were very inexpensive since they were bad. I bypassed the bad cells with a heavy jumper and the remaining cells work fine.
Another alternative are used Nissan Leaf cells, which are fairly inexpensive and pretty easy to find.
Ok thanks, i will pass on them and just use lifepo4 like i was originally going to.
