Hi,
I had a deal on a second hand full suspension giant yukon fx and I'm slowy getting ready to convert it to an ebike. I wanted to convert a hardtail but the streets are way too bad here in Montreal. I would like to keep the setup as simple as possible. I wanted to used a geared hub but I think I'll go with a DD because of it simplicity and I could use regen to save the brakes a bit. I tried a BBS02, its ok, but for commuting it might not be the best.
Desired max speed on level ground. mph or kph = 50-55 kph
Average speed: 35kmh
PAS ( I always pedal)
Desired max range at what cruising speed 20-30 km @ 35 kmh
Preferred bike wheel size, or wheel size of bike you want to convert. 26 inches
Brake type of motor wheel. Disc
Rider weight. 140 lbs
Terrain. Exp: mostly flat / mostly road
Budget for motor : +/-500 usd
Bike: https://www.giant-bicycles.com/en-US/bikes/mountain/1382/29355/
Battery: still looking, looking for 48v 10ah
There's this kit on aliexpress. Which look like an overvolted fast winding 9c clone
https://www.aliexpress.com/item/Passion-Ebike-48V-1500W-Bicicleta-Electric-Bicycle-Bike-conversion-kit-Rear-wheel-motor-kit/32476876343.html
and There's the leafbike kit:
http://leafbike.com/products/diy-bike-conversion-kit/26-inch-electric-hub-motor-kit/newest-version-26-inch-48v-1000w-rear-hub-motor-bike-conversion-kit-1067.html
Here's a couple email we exchange about the kit (top = newest). I won't pretend I understand everything about motor turns. I get that less turn= faster but the first number, I don't undestand... What do you think of his answer?
Also, How does the rear air shock will react with the new 18 pounds wheel?
Thanx!
Hello Philippe
13*5T is much better. Top speed is about 55km while you ride.
(Also,our LCD can set max speed)
1 year warranty for replace part or repair part.
Best Regards
Peter
Leaf Bike
Sent: Thursday, October 6, 2016 8:34 AM
To: sales@leafbike.com
Subject: Re: 1500w kit infos
Hi Peter,
Maybe you can help me with the motor turn. This is what I’m looking for:
-bike (26inch full suspension) + Rider + battery (48v 10ah 25r cells) + motor with be around 200 lbs
-cruising speed around 35-40km/h. Mostly flat. I pedal most of the time
-top speed (burst) 55-60 kmh -> I could trade top speed for torque. 50kmh burst could be fine.
Also, what kind of warranty do you offer on the kit?
Thanks!
Philippe
On Oct 4, 2016, at 9:48 PM, <sales@leafbike.com> <sales@leafbike.com> wrote:
Yes,you could order other winding rotor.
For example: 13 * 5T, 11 * 6T....
Just when you order,Note: winding size or max speed.
(Then we will ship motor as your Note)
It comes with LCD-003.
Best Regards
Peter
Leaf Bike
Sent: Wednesday, October 5, 2016 9:43 AM
Hi Peter, is it possible to order a different winding to have more torque ? What's the display that comes with the kit ? Is it the lcd3?
Le 4 oct. 2016 8:24 PM, <sales@leafbike.com> a écrit :
Hello Philippe
Default: 16 * 4T
3mm phase wire
Can ship by China Post, SAL.. but they are very slow,hard to track parcel.Also,not much cheaper,cost about $140USD shipping cost if ship by SAL,China Post.
* Continuous current is about 20A,max 40A.
* Regen works.But not strong. ONLY a little regen while braking. (Strong regen will break controller)
Best Regards
Peter
Sent: Wednesday, October 5, 2016 8:08 AM
Subject: 1500w kit infos
Hi!
I'm looking at this kit http://m.leafbike.com/mobile/products_detail.php?ProId=987
How many turns do the motor have? What's the size of the phase wire ?
Is there a cheaper way to ship the kit to Canada (SAL maybe)
What's the continuous current of the controller ? Does Regen works ?
Thank you!
Philippe
Thanx!
Hello Philippe
Best Regards
Peter
Leaf Bike
Hi Peter,
Thanks!
Philippe
Best Regards
Peter
Leaf Bike
Hello Philippe
Default: 16 * 4T
3mm phase wire
Best Regards
Peter
Hi!
Thank you!
Philippe
