Need help identifying this 30 amp controller
Chula Vista
Hi,
I need some hel identifying this 30 amp controller and what display would be best to use with it.
Thanks in advance
Cryingmadman
“Ideas are easy execution is a bitch”
Marie Antoinette
You need to take inventory of the plugs. Not every controller supports a display. That one doesn't seem to bear any brand markings to suggest what display it might get along with.
If you post a foto that shows all the plugs, maybe we can help you by process of elimination.
If the battery power plug has a thick black wire, a thick red wire, and a smaller red wire attached to it, then the controller probably doesn't support a display (because the smaller red wire is the enable switch rather than the display having that function).
Thanks
any chance you could tell me name of Motor connection on controller?
Cryingmadman
Marie Antoinette
That looks like it might be a Julet Z916. Can't really tell. Those have been used extensively on Rad Power bikes, so maybe you can look for pictures of Rad controllers and see if the controllers are like what you have.
Thank you
Any idea what display would work with this controller?
Cryingmadman
Marie Antoinette
You Welcome!
If you get a chance to take a pictures of the inside of controller, please post it. It maybe helps to other people.
