This is what I have done but it won't turn on so far. I have the qs motor, kls7230s kelly controller, battery, and a full twist throttle. The anderson powerpoles I connect the battery to kelly controller's red and black. I assumed the 6 pin on the qs motor goes to the kelly controller 6 pin, and the qs motor's green, yellow, blue ring connectors goes to the kelly controller's green, yellow, blue ring connectors. Then according to the kls7230s manual, for the throttle, there is a 9 pin, I should connect the green pin on the full twist throttle to the top middle of the 9 pin, middle left is black, bottom left is red, then i'm not sure what yellow and blue is for.
Can someone help me figure this out?
Thank you.
Link to two pics.
Throttle connectors.
https://ibb.co/ggSnrv
QS motor and kelly controller setup.
https://ibb.co/fVsLBv
Thank you.
Link to two pics.
