Need link to Newest app for old 2020 Ant BMS
Stormsorter
100 µW
Finally got around to building my in frame main battery and hooked up the 80amp Ant BMS I bought in early 2020. Everything seems fine except charging current, software shows 2 amps instead of 5. Before I bother timing it or hooking up a bench power supply to confirm if this is bad hardware or software display issue I decided to come here and see if this is a known software issue with older versions of the Ant/Mayi BMS and VBMS apps? I bought VBMS long ago but am stuck with an old version since the last phone I logged into a Google account on was an S5 so I couldn't update to anything past v2.1.2. I was tempted to log in on a device that never gets used but VBMS no longer shows up on the Play Store so that seems pointless. The only copies of the Ant BMS app I can find are 1.0 and 1.3 from rjxzstech or the newest version from antbms.vip. My understanding from a bit of searching and reading is that 1.3 or newer doesn't work with the older Ant BMS's like mine. So basically I need a link to the newest app for old 2020 Ant BMS.
