Well, then the EVG gets to looking a lot better for you for sure. You have experience, so you know what's ok and what's not with lico.
I started out with lead, nicads, and lifepo4, but now run only lico because I could replace lico cheaper than I could replace my lifepo4.
No bms, I find the key thing to be to sort the packs and remove any that have cells that don't perform well. Then, by running a conservative dod, I don't unbalance the pack every ride. This allows me to simply monitor whole pack voltage as I ride, with no worries about one cell going into overdischarge. I try to stop when I am at 3.7v per cell or sooner.
The idea is, build a pack that tends to stay balanced, then don't pound it into unbalance. Then no bms works fine. The down side is each 5 ah pack produces only 4 ah you can use, so you have to upsize the whole pack to have good range.
Unless I misunderstand, you already got the 10 ah lifepo4? If you want to, you can parallel some lico with your lifepo4. You can connect 14s lico with a 16s lifepo4, and the voltages are pretty close. It worked for me, when I was squeezing the last bit from my lifepo4 that was too weak to run my bike by itself anymore.
