I have a never used 72 volts 24.5AH triangle battery. I purchased it new from China about 8 months ago it is 20S7P and it is 1/2 inch too tall to fit into my Frey HT 100 frame. Currently a 16S8P is installed using a PR. This is totally my fault!
Anyway, I need to preform some surgery and make it physically smaller by 15 mm or more so I want to remove these 7 cells, and then relocate the remaining cell in the second row. This will reduce the dimension I need reduced by about 25mm.
Need advice:
1) How to cut the nickel strips?
a) use a Dremel cut off wheel and a steady hand.
b) use a small side cutter pliers,
c) ??????
d) On the one cell from group 2 that I need to relocate, can I solder the two nickel strips if I overlap them? This will only carry the current from one cell.....? I do not have a welding setup....
2) What do I do with the #1 BMS wire that I will disconnect?
a) leave it disconnected.
b) Attach it to another cell (two on one group.
c) ??????
3) What about the 20S cutoff voltage from the BMS?
a) If only 19 connected will this reduce automatically?
b) I will set the PR / CA3 to correct 30% cutoff for 19S, just wondering if the BMS will be cutting it off based on 20S??
Need advice:
c) ??????
c) ??????
