If the hall sensor is located exactly at the middle of the magnet you could have no flux in the direction of the sensor axis (fail). If the sensor axis is off a little from the middle of the magnet, it should work fine.
If you powered a sensor and watched the output while trying different positions you could verify a good signal.
