However, the m(echanical)-part have been a different story. Along the way, I replaced :
1) Several sets of tubes and tires from punctures, flat, leak, worn-out thread, etc.
2) Broken few spokes especially on the rear. Replaced the whole set of 32-spoke on rear wheel. If anyone need to replace their spokes (32 or 36 counts), recommend bigger wire gauge to make it more durable. Additional weight is negligible compared to the benefits received.
3) Been hit by a motorbike head-on (the guy ran the wrong way against traffic) cause bent front rim and need to replace. Luckily that just the front rim was damaged, if I took off 0.5sec sooner, I would have been seriously injured.
4) 1 rear hub (worn-out), 1 chain, 1x 9-spd cassette
5) Brake discs : front and rear, worn-out, bent, squeak, etc. I ordered a whole set of F+R Shimano 4-piston MT520 calipers, MT501 levers, metal pads, hoses, oil, and replaced with my old entry-level 2-piston Shimano M3XX set. They are for my front 203-mm and 180-mm rear discs. These new brake set have proven on several occasions that they worth their quite high $$$, especially when I needed that emergency stopping power. Hope I don’t need them that often, LOL!. Been using them for about 1.5 months and 1,2xx km now. BTW, need to manually tweak the magnetic sensors for the new hydraulic brakes L+R too. I used small 10-mm neodymium buttons to do this, proven reliable as my 1st set of the very similar thing.
6) 2 broken chargers : 1 sudden death charger from Lunar Cycles after only few months of usage and the second one YZPower 58V4A is just yesterday after about 1.5yrs and 200+charges.
7) Install new wattmeter with shunt resistor near the motor & batt pack. So I run only small 4x0.25 wire to the dash board. Compare to those main current carry Turnigy/GT power in-line watt meter that require 4x6sq.mm. wires. Much tidier now.
8) I did a complete re-grease the BBSHD @6,400km ,everything inside was intacted. Using the Mobilgrease-28 even before the 1st ride, that nylon gear was still in perfect shape. Adequate and proper maintenance really matters. One thing I see need improvement is the silicone putty separating motor internal, controller and wires connection chambers. That silicone needs complete clean-out to remove phase wires before accessing the motor to re-grease that nylon gear. This is troublesome. Someone has a better solutions ?
9) New comfortable saddle – for better care of my rear end
10) Smaller mechanical problems wears & tears, here & there.
