methods said:
That does not make any sense to me. Halls should be totally isolated from phase voltage..... (unless they are mechanically shorted
If they are blowing due to induced noise then that can be handled with some inline resistance and a bypass cap like you see on the 9C boards. I would love to see the original information regarding this voltage issue. I have certainly seen a lot of hall failures with Crystalyte motors (and not a single one with 9C motors...) but most of the failures were mechanical in nature... i.e. the wire desoldering from the hall leg.
-methods
On Tue, Aug 16, 2011 at 3:31 PM, Crystalyte <crystalyte@yahoo.cn> wrote:
> Hi Wojtek,
> I have found the problem why the HT and HS sensor not reliable. We are using
> the HONEYWELL 41F sensor. It is just available for 48V system.
> If any client take the motor with 72V then the hall effect sensor will be
> cook.
> HONEYWELL SS40 sensors :
> We do check the SS40 may not good for bicycle motor.
> - The ss40 design for small slow speed motor.
> - Also it is design for lower voltage system. The 72V or more voltage system
> will brunt the sensor as well.
> Please check on your side as well.
> HONEYWELL 43F sensors :
> HONEYWELL suggest we take the 43F sensor for 72V or higher voltage motor
> system in biicycle.
> What do you thik?
> It is the reason for me asking about what about the motor for what voltage
> in last mail.
> By the way, for the high voltage motor which most take for 72V or more. We
> will make the 5400 motor with deep slot on the silicon sheet. So it must
> reliable.
> Feel free mail me for more information.
