methods
1 GW
Arlo1 said:.... I have 2 simple solutions that have proven themselves very worthy, Cooling fans ........
yes
A wise man you are.
Now who is going to be the first to water cool???
-methods
Ive got the motor and just rewond it but I need a real controller.... So guess I need to design/build that on my own. Sorry its not a frock....methods said:Now who is going to be the first to water cool???
-methods
Bad idea..rui_fujino said:If any of you are going to watercool the motor I think you should think about using peltier to cool down the motor.
The stator I put a picture of has water jackets inside it!rui_fujino said:If any of you are going to watercool the motor I think you should think about using peltier to cool down the motor.
you could easily attach the patch on the motor surface and release the heat to outer motor...
http://en.wikipedia.org/wiki/Thermoelectric_effect
also i think this method is so much cheaper then water cooling...(also less maintenance) :wink:
Arlo1 said:Methy I haven't burnt any motors! I hammer the throttle hard all the time and do all the stupid shit these motors hate. I have 2 simple solutions that have proven themselves very worthy, Cooling fans and heavy duty dropouts with pinch bolts!
rui_fujino said:How come peltier is a bad idea? As far as my knowledge goes, peltier can be bought within $25 per one, and they can be fitted to the side of the motor and use coolent aluminium on the outer side of the hum
Arlo1 said:I laced mine with 12 gauge and they are loose but once tight it seems fine!biohazardman said:OK then now that I have read the whole thread through at least twice I still don't see what people are doing about the huge holes they drilled for the spokes in these things like 4.2 mm. My 12ga Sapim spoke has a 2.6mm shaft and is 5mm max at the widest part of the head. So a very sloppy fit and only .4mm overlap on the motor flange. I really wanted to get this thing done like yesterday so I expect with that in mind it will take years? ;^) Spoke washers for a new motor? What have you done or have you had the problem?
I just ordered 10. I plan to install one over every window in the staped steal in the center of the stator. I drilled small holes on the very out side of one cover next to the windings and big holes toward the center of the oposite cover with the intention that the fans will pull the air in from the holes close to the center on one side and below it sideways till it goes out the holes right beside the windings on the other side.wojtek said:Arlo1 said:Methy I haven't burnt any motors! I hammer the throttle hard all the time and do all the stupid shit these motors hate. I have 2 simple solutions that have proven themselves very worthy, Cooling fans and heavy duty dropouts with pinch bolts!
cooling fans installed how? I take some of the members tried this but it was inefficient?
Arlo1 said:I just ordered 10. I plan to install one over every window in the staped steal in the center of the stator. I drilled small holes on the very out side of one cover next to the windings and big holes toward the center of the oposite cover with the intention that the fans will pull the air in from the holes close to the center on one side and below it sideways till it goes out the holes right beside the windings on the other side.wojtek said:Arlo1 said:Methy I haven't burnt any motors! I hammer the throttle hard all the time and do all the stupid shit these motors hate. I have 2 simple solutions that have proven themselves very worthy, Cooling fans and heavy duty dropouts with pinch bolts!
Sorry this os thwe only picture of the stator I can find ATM.
sn0wchyld said:I ended up geting mine laced with 14g spokes and using SS washers. the washers ended up flexing a little so they seat in nicely and so far seem to be holding well. I was pretty reluctant to do it this way initially but a 3+ week wait for larger spokes (that still may not have worked) was too much for me to bare given how long it took me to get the bike running.
Ill have another look but I just yanked the seal and ziptied the wires in because the seal 100% CAN NOT SEAL on a surface with a slot in it like that!methods said:Lol, where have you been bro?
We have been talking about this for 5 months![]()
All you have to do is rotate the plastic wire guide and cut a new notch. This holds the wire down below the seal. Go back and look at your plastic wire guide, it was machine incorrectly with a "mouse hole" that allows the wire to come up into the seal.
-methods
Andje said:no 65 is nothing. i was pushing 120 C on my hs when they failed, and it was due to thermal destruction of the enamel. Neo magnets are good till 300 degrees C or a lot more depending on chemistry.
methods said:sn0wchyld said:I ended up geting mine laced with 14g spokes and using SS washers. the washers ended up flexing a little so they seat in nicely and so far seem to be holding well. I was pretty reluctant to do it this way initially but a 3+ week wait for larger spokes (that still may not have worked) was too much for me to bare given how long it took me to get the bike running.
Keep us updated on this....
I have tried brass (a bit too soft) and I am eager to hear how your SS hold up.
-methods
fractal said:Anybody know what size bearings these motors have? I want to upgrade to ceramic bearings.
mvly said:Can anyone confirm the speed I should be getting at 2.5KW power input to my HS3548? I tested it yesterday night and I clocked it at 35mph at 2.5KW power input from the Cyrstalyte Sensorless Controller. One more thing I have an oscillating Current limit on my CA. I set the Current limit to 31A and when I pass it, it will slow the current down, but then it would slow it too much and take it to 28A which means I can go up again. Then it would pass 31A again and Oscillate back any forth. Any Ideas how to fix this? I have Justin Large Screen CA. My guess is to mess around with the Feedback/update units to see if that fixes it.
nicobie said:I also think it's a good idea to replace the bearings. On my 1st edition HT3225 they went south within 100 miles.
I have had my new HT3525 up to 85C and the windings still look like new.
