Okay, just to say first of all; I'm completely new to all of this, and am based in London, England....
I recently bought one of these 1000Watt Brushless built-in hub motors from my beloved eBay; installed it fine, and it comfortably takes me to and from Uni everyday [an 12 mile return trip] at a top speed of around 20Mph...
Having had it about 3 weeks; it's still taking me a good 25 mins either way; so I was looking to increase the speed; I've read about over-volting [to a limited comprehension extent] the controller in order to do this; however from my basic knowledge of physics Watts = Volts x Current....
Now using the batteries supplied with the kit - 48V at 14Amphours what on earth is the wattage. I only ask, because the motor is rated to 1Kw, and I don't want to damage it...
I was thinking of getting six of these 12v 7.5Ah Batteries to make a 72V combo.
Is it really that simple? Would the controller then 'see' the new increased voltage, and whisk me along faster? [Albeit at the expense of battery life]
Basically, I'd love to be able to do a constant 30ish if it all possible; more if achieveable! To reduce my travelling time, there aren't many hills, and terrain is relatively flat, so 'strain' on the motor shouldn't be a problem? Also, it's about 5 Degrees Celcius here, so heat shouldn't be a problem either?
I should probably point out, I ride along bridleways, which are legally 'off-road' and have no speed restrictions.
Any help with speeding this little beauty up would be much appreciated!
Regards,
Quillist.
Regards,
Quillist.
