MitchJi
Hi,
http://gas2.org/2009/10/06/new-nick...-ultrahigh-energy-storage-capacity/#more-3724
New Nickel-Lithium Battery Has “Ultrahigh†Energy Storage Capacity
Researchers have found a way to create a battery out of Nickel and Lithium that can store more than 3.5 times the energy of lithium-ion batteries and are much safer to boot.
Lithium-ion batteries are great and allâ€â€having heralded in a new age of portable electronics and allowed for the possibility of mass-market electric carsâ€â€but they have a few major drawbacks. For instance, they have a propensity to catch fire and explode and, although they have a much better energy storage capacity than say lead-acid or nickel metal hydride (NiMH) batteries, they still weigh too much to pack more than a couple hundred miles of range into a passenger car.
Your standard issue Li-ion battery can hold about 55 watt hours of energy per pound of battery. Today’s modern electric cars need about 25 kilowatt hours (kWh) of power to go 100 miles. As an example, The Tesla Roadster has a 53 kWh Li-ion battery pack and goes just a bit more than 200 miles on a full charge.
Doing some calculations, you’ll find that the weight of a Li-ion battery quickly becomes the limiting factor in increasing the driving range of an electric carâ€â€you need roughly 500 pounds of Li-ion battery for every 100 miles or range, give or take. Taking the Roadster as an example again, its battery pack weighs about 1000 poundsâ€â€just a bit more than 1/3 of the entire car’s weight.
Taking this dilemma head-on, Researchers at Japan’s National Institute of Advanced Industrial Science and Technology (AIST) have combined the recent discovery of a special glass ceramic film called LISICON with what would normally be two incompatible battery materialsâ€â€Nickel and Lithiumâ€â€and have succeeded in making the world’s first Ni-Li battery. It can hold more than 3.5 times the energy of Li-ion batteries and doesn’t run the risk of catching fire.
How Did They Do It?
A typical battery works by separating a cathode (positively charged) and an anode (negatively charged) in some sort of electrolyte. The difference in charge between the cathode and anode is what generates electricity. In a Li-ion battery the electrolyte is an organic solid substance (part of what makes it prone to catching fire), whereas in both lead-acid and NiMH batteries the electrolyte is a liquid (much less prone to catching fire).
Usually the electrolyte separating the cathode and anode has to be the same substance. Because of this, the cathode and anode materials both need to be compatible with the same electrolyte, which has restricted the choice of cathode and anode materialsâ€â€up till now.
By separating the cathode and anode with the special LISICON material, the AIST researchers have found that the cathode and anode can be placed in two completely different electrolytesâ€â€allowing for much greater flexibility in the choice of cathode and anode materials.
Further reasoning that by combining the best properties of NiMH batteries with those of a Li-ion battery they could obtain an “ultrahigh†energy density, they placed a nickel hydroxide cathode in a liquid electrolyte and the lithium metal anode in an organic electrolyte separated by the LISICON glass.
And voila! The world’s first Ni-Li battery was born. Their experimental battery cell has already obtained a “practical energy density†of about 194 watt hours per pound of battery material.
Imagine if that Tesla Roadster had 1000 pounds of Ni-Li batteries in itâ€â€that’s a 700 mile range. Certainly an improvement, no? Now we just need to figure out how to fully charge it in a reasonable timeâ€â€on a standard household outlet it would take the better part of three days.
Granted the Ni-Li battery has some hurdles to overcome, namely that is an incredibly complex battery and manufacturing it may be difficult. Also, the LISICON glass would need to be durable enough to resist breakage over the expected life of the battery. But humans have figured other more complicated things outâ€â€like thisâ€â€so it’s really just a matter of time.
