Ok. I am interested in trying to build a 2 wheeled recumbent motorcycle that is gas-electric powered. To clarify I want to use something like a smaller 250-500cc MC engine running an optimal RPM to only power a generator that charges a battery. The battery would then be used to power the all electric final drive.
Now to cover some general bases. The bike would be longer to accommodate the engine, the batteries, and the seating position. What I have envisioned would have the motor forward the driver, with the batteries and final drive motor under/behind the seat. It would be equipped with a fairing if not an entire body. Similar to British Monotracer or Lit Motors self stabilizing bike, however it would likely be stabilized by good old leg power. I would like this bike to be able to handle high speeds easily. I live in an area that would require at least comfortable handling at 50-60 MPH
My Logic
It makes sense in my inexperienced mind that you could essentially optimize the energy produced by a small efficient gas engine by storing it in a battery bank, and using it as needed it in an electric final drive. If you were to entirely deplete the battery, then you could theoretically still affectively power the bike from power directly being produced by the engine.
The end result would be a bike that though is heavy, it would require less batteries, waste less gas. have the improved drive characteristics of an electric motor, but still have range and be instantly refillable.
Questions.
1) Is it worth doing generally? Is my logic solid-ish or am I being unrealistic.
2) If I am on solid ground would it be safe to assume, because of the constancy of the generators action, and the variability of the motor on the drive train, would it be reasonable to have a less powerful generator than final drive motor? primarily just for reducing weight.
3) I don't know a great deal about motors. I would like to use a BLDC. I live in a hot environment so I was considering water cooled. Since the bike will be heavy and have gasoline backing it, I would rather go big. I know some of the all electric sport bikes use up to 94ish volt motors, but they are also made of carbon fiber. I've seen everything from 36 to 114 volts. How big is big enough? At what point is there diminishing returns.
4) How will the constant recharging of the batteries affect the total amount of batteries I need.
5) Is it at all recommended to build your own batteries using individual 18650s or is it best to just get something like the Nissan leaf batteries?
6)Assuming that I am on a decent track, recommendations for what components would be nice. Motors, engine, batteries, charging units, controllers, etc.
7) I've read lots of pros and cons on transmissions. I know they are generally not necessary, but I may spend a significant amount of time at higher speeds. I toyed with the idea pulling a transmission from a bike, building another housing for it and trying to basically having a two speed transmission. One for general poupose, and one for long stretches at high speed.
#8) Are there any pre-drawn plans, diagrams, books or references for this kind of thing set up online or purchasable somewhere. I have a hard time searching for it because searching "gas-electric/petrol-electric" pulls up everything but what I'm looking for.
The reason I like this idea, is I feel that doing building it this will give me slightly more design freedom and reliability than just a standard MC build. Being able to kind of bring these elements together allows me to make adjustments more or less where ever I think would be necessary. essentially the entire drive train from beginning to end becomes connected by flexible wires and belts.
I realize I'm being ambitious, but please I welcome all of your knowledge and insight. I am new to this world, and I find it increasingly fascinating. I feel like it will play a big role in the future, and I want to at least have a better understanding than I currently do. I greatly appreciate any information. If I'm way off track please don't hesitate to tell me. I'd rather stop while I'm ahead.
PS as kind of a side note, I would like to do a gas-electric build of some kind. I am a MC fan, and I feel that this would be the "cheapest", most practical, and fit in my garage. However I also like the idea of doing a trike or a small car in a similar manner, so if this in impractical for an MC but not a car let me know.
My Logic
Questions.
