LI-ghtcycle
I posted something on this in the Battery section, but now I want to talk more to the construction of the main battery case holding the battery packs.
I made a cardboard template for all available space inside my newer Trek frame's triangle and used another template of the cross section of a 28v Dewalt battery pack minus the case and BMS.
First off, I was amazed that just removing the battery from it's main plastic case (still keeping the internal black end caps & BMS for now) I reduced it's weight from 2 to 1.5 lbs!!
With my plan to use 16 to 18 parallel 8 cell groups, this is a weight savings of 8 to 9lbs!!. Of course I will be gaining some weight from the battery case and BMS I will be adding, however I believe it will be less than the former pack design I had that required building a mount for each individual battery that included a PCB interface board that had to be soldiered up for each Dewalt pack.
Here are pics of the cardboard template:
And here is a link to the other post showing a lame drawing of the battery case I would be making out of thin (3/32 in.) ABS sheet with tabs to attach to the bottom tube and seat tube:
http://endless-sphere.com/forums/viewtopic.php?f=14&t=19177
The Idea is to have the batteries and TP Packs BMS inside the case with some form of active cooling fans located in the top back corner just underneath the top so that rain wouldn't be dripping into them, and vents all along the case sides that wouldn't let rain drip inside but would allow air flow around the batteries and most importantly the BMS. I might even tuck the controller inside if it's practical, or there isn't room, and it wouldn't hurt the performance, I might have the BMS in a second case on the back rack.
My main concern is that the batter case has to open similar to a "clam shell" and the left side would be fixed, and only the right side would open with either just the flex of the plastic or some kind of hinge at top. The individual battery packs would be secured with a "binder bolt" (the type of fasteners that look like 2 bolts on end with one being the "nut" that the other screws into) holding together the black plastic end-caps inside the Dewalt packs.
These packs would then be secured inside of the form fitting plastic case with 3/4" wide velcro strips so that they could be tightly held in place from all angles. The bottom of the case would again be secured with binder bolts (I suppose they could be T10 just like the Dewalt packs or other tamper resistant fastener) and a charger would be attached as well so you wouldn't have to do anything more than plug it in for charging. My goal is to have a charger capable of charging the entire pack at the same rate as the Dewalt packs charged, so a full charge would take 1 hr or less depending on SOC.
Thoughts?
Thoughts?
