Afterburner
10 µW
Just got a 48v 20ah V Power from Cammy on Ebay. Charger was cracked and the BMS' white box had multiple loose screws. Be that as it may, I plugged it in and left it charging for about 8 hours. The BMS system utilizes two sets of white wires and each set plugs in to a separate terminal in the BMS housing. Two lights came on, marked LED 1 and LED 2. I noted the left LED had turned green as expected while the right LED 2 stayed red, even after another 4 or 5 hours on the charger. I wrote Cammy and they said the left LED is the only one that turns green. The red one stays on only to indicate the power is on. I was curious to see if that's the standard set up for these batteries, so any comments would be appreciated.
Also, if anyone's interested in hearing about the 48v 11.6 Ah "Dolphin" style batteries I ordered directly from China I'll be happy to post a rundown on the cost, testing etc. once I've had a chance to try them for a while. Thanks again to this group!
